Good AFRs... Still possible to blow a motor?
Originally Posted by kjewer1
Couple points.
With the stock ECU or something based on it, adding boost will either keep the same AFR, or it will go richer (higher load level map), assuming the fuel system is adequate...
l8r)
Originally Posted by Rviscosi
To much timing also causes too much heat.
There is a point with any given fuel octane where increasing boost pressure only causes the need to further retard the ignition timing, and creates no more power than a lesser boost pressure with more appropriate timing. What it does increase however is EGT, which is detrimental to everything in the exhaust system, including the turbo.
SterlingEvo,
Hahaha... Yeah, I'm sure it would. I dont think I will ever have that problem. I was close though, I didnt full tighten the oil pan bolt and it started to leak slowly. Thank god I checked it all again before I put everything away.
Ludikraut,
I dont have my Tactrix cable yet to verify the maps by ECUFlash. Supposedly, Al tunes for a low and high octane map. I didnt feel any difference running 110 at 20 psi. Not too much more at 22 psi, then again it's only 2 psi.
BlackEvo110,
I run 91 octane over here in San Diego. I wish it was better but what can I do. I've only ran 110 twice to date. This will be my 3rd time. I know a lot of people who run leaded constantly and have had no problems. I dont think it is THAT serious with clogged injectors. Once every now and then cant hurt.
I do have the stock ECU, but I believe Al has tweaked my fuel and timing maps. It took well over 3 hours to tune my car... I sure hope they have been changed for optimal performance.
Ludikraut,
BlackEvo110,
Originally Posted by Ludikraut
You'd also have to assume that the stock fuel map is still intact. Something that's easy enough to verify these days with ECUflash. If more fuel isn't being added for each successive load column at any given RPM, then you'll start to run leaner as the ECU hits the higher load cells.
l8r)
l8r)
Originally Posted by pog0
I've searched, but couldnt find too much info. All I really found was this:
https://www.evolutionm.net/forums/sh...=blowing+motor
I just installed my AEM wideband gauge and I have been going WOT til about 5-6K on the freeway from 3000-3200 in 5th and 6th gear. In 5th at 1 bar, my AFRs are from 10.4-10.9 in 5th and 6th. In 6th gear at 1.4 bar, it is about 10.9 - 11.3. 6th gear at 1.45 bar it went from 11.4 down to a solid 10.9. I am tuned for 1.4 bar with other basic mods, Al said 1.5 bar was too much boost during my tuning session.
I know I didnt give too much info and Im not able to log anything but my main question is... Is there any other way to blow my motor if I raise the boost and have good AFRs?
I plan to go to the 1/4 drags in two weeks and I am going to run 110. I dont want to crank up the boost too much if it is going to cause severe damage.
91 octane tuning is really a seperate world - my tuning settings are very safe at normal pump gas boost levels at pump gas bost levels
a/f richness has a certain calming effect on knocking and within reason going a bit rich will help you hold more timing without knock which is one of the reasons I tune on the rich side, particularly witrh 91 octane
regardless of the a/f with 91 octane you will knock badly if you raise the boost too far
My general suggestions are
91 octane 20.5 psi max
93 octane 21 - 22 psi max
100 octane - 26 psi max
116 octane leaded fuel - 30 psi
With my tunes you can just pour in race gas and turn up your boost
Without turbing up the boost adding race gas alone will not add any power in fact it may slightly lower your power
l8r)
l8r)
The load calculation uses the a.f target and the MAF sensor scaling (plus or minus other active fuel trims) to achive the desired inecjtor on time
With a properly set up map, the car will run a steady a/f from 19 psi to 28 psi or when you exceed the capacity of the maf sensor or run off the end of the fuel map
Originally Posted by DynoFlash
Remember the stock fuel map is a a/f target not a duty cycle
l8r)
Registered User
So besides good afr's what would be the ideal target for egt's on 91 oct., 93 octane if tuning to say a 23 psi spike with a taper to 18/19 psi on a mbc? Anyone with a 91 octane tune with a egt gauge care to chime in?
Other then that ARE electronic boost gauges a little bit more accurate then the good ol' mechanical boost gauges?
Experience and hands on time is what gives you the knowledge to know what changes result in what effects on the car and internalize all the workings
Some cars can run lean, some have to be rich
Its a matter of "feel", experience and some natural knack
Rich with methanol and more timing
Couple points.
O2 sensors will usually survive leaded fuel if you put at least 1000 miles on them first with pump gas. The coating they get protects them. I usually go 2-3 years between sensor changes doing it this way. Earlier this season however I got greedy and only put ~350 miles on a new WBO2 sensor before going to leaded. It didn't last 2 weeks... This sensor got about 750, and it's still dead on with DSMlink AFratio after about 3-4 weeks. 1k is a good rule of thumb.
This is why it pays to monitor AFR real time, not just when you are getting tuned. I know it's not in everyone's budget (though 300-400 for a WBO2 setup is less than what some people will pay for a BOV and some exterior modz), but it's a worthwhile investment. The sheer amount of data I've amassed over the last 5 years or so is unreal.
