white smoke
white smoke
I had a crack in my header, so I replaced it with the stock ones. Then, I put on a new stock hotside. Anyway, once I replaced everything I started the car and a lot thick white smoke came out of the exhaust. I mean this was thick, 15 to 20 seconds and the area was filled with the smoke. I was told it could be a blown head gasket, cracked head, or a turbo malfunction. Anyone have any other ideas, or can confirm that its any of the problems I have listed?
How sure are you cause I dont have too much money to spare, and I dont want to be buying extra stuff. Im not going to be replacing it myself so I have to pay for labor also. If anyone else has some input please let me know.
it only did it for a few seconds? How does the car run? does it do it everytime you start it when its cold/ If not, was the manifold in contact with oil ar anything that would burn off. Seems strange to me that swapping aheader out would do anything, unless there was **** in the manifold and blew through the turbo
Are you sure it was white? Oil smoke is a very light blue (almost white) and can be mistaken by the untrained eye (but not the nose). As stated earlier, it could be WD-40 or other light oil or the rust preventitive on the manifold from the factory.
The 'white smoke' from water in the exhaust is steam and will disapate quickly and smell sweet, burning oil will hang in the air and smell nasty.
Good luck
Good luck
