Cosworth M2 cams?
That depends on what you mean by 'aggressive'. The higher lift and short duration makes for a much more aggressive ramp profile than any of the HKS cams, which should improve spool characteristics and midrange response.
You are correct in that they do not appear 'aggressive' when it comes to effective duration. Allow me to correct myself in that they should be expected to show shorter duration at 0.050" as opposed to the 1mm (0.040") measurements commonly used for import cams. While the true effective duration isn't quite as short as I indicated above (apologies for any confusion) however (and FWIW, Revolvers and especially the JUNs appear to have longer valve timing) if that proves to be of any real, measurable advantage for most setups remains to be seen.
maxroach
Jul 22, 2017 05:07 PM
FS[SouthEast]: Mivec Cam Gear
hutch959
10
Nov 25, 2016 05:35 PM
FS[Northeast]: HKS evo 8 cams
real fast
Aug 27, 2016 04:55 PM
bryonboals
Jan 21, 2012 07:58 PM
boostinmarc4
Apr 22, 2010 06:22 PM
