My MBC mounting solution
I just thought I'd take a sec and see what you guys thought about my MBC mounting bracket that I fabbed up and incorporated into my MBC installation. I think it looks really clean and almost looks OEM from a distance. It also keeps the boost lines really short which is a plus. This pic is a crappy phone pic but you can see the bracket design well. Also it looks like the MBC is close to the mani but you can get your fist in between the two everywhere so it's not as close as it looks. I'm happy with it and just wondered if you guys thought it was a cool idea. Thanks....
I still think it's too close to the head/mani. A great place for the Hallman is on the far radiator screw, because that hides it directly beneath the stock intake snorkel with only the head of the MBC sticking out for adjustment. Back when I was running my 12.2s with cat-back and Hallman MBC, I had no visible engine mods except this one, and people could never find it.
Well I will be running the APS intake so the snorkel will be gone and not sure if I could mount it on the radiator screw with the new APS IC sprayer reservoir or not. Plus I dont mind showing off my mods but I just want everything to look clean and I think this does. This also keeps the lines shorter than mounting it on the radiator, but that's not really going to be noticeable. I'll have to take a pic from the other side tonight so you can see how it has pleanty of clearance with the manifold. The heat should not effect it at all.
Great bracket design. I dont think that it is too cose to the manifold/head, it should work fine thre plus the lines are kept nice and short. The only issue might be if you are running a tubular manifold.....
Looks good!!
Looks good!!
Good point on the manifold but I doubt I will ever do that unless I go ***** out with this thing in a few years but I dont think I will do that. I will be happy with the ported and coated stocker at least for a while. But that pic does make it look super close to the mani but from the other side angle it looks right. I got in too close with my phone because the screen is so small. I couldve backed up a bit, but at least you can see the bracket design which is the point. I have seen people post for suggestions on where to mount their MBCs before so if this gives anyone an idea, it was worth posting about.
I promise you it is not too close so don't worry. Looks very clean also, good job.
I had mine mounted near there for quite awhile with a tubular header with no problems. In fact even right now my lines run within a few inches of the header and its never had a problem yet.
Originally Posted by Ultimateone
Looks good, but as Warr said it does look somewhat close.
i saw it last night it's fine. like he said if he has some kind of problem with the heat coming off the header he can move it.
If his intention was to hide it i dont think it he would have put it there. The lines are short and are ran far enough away that there wont be a problem. i dont see to many people with theres in the postion. Congrats mike....to bad my car was cleaner than yours last night...lol
Originally Posted by ONRAILS
shoulda hid it .. glove box
