Problems with Injen intake for evo IX
#31
So, when you moved the BCS to its new location, you did not disconnect the vaccuum line going to the turbo?
#34
Originally Posted by res04
remove injen intake. return to stock. throw injen intake in trash. enjoy your trouble free Evo.
#35
Well finnaly after being up for about 32 hours screwing with it I just pulled to front bumper off and checker the sleeve at the intercooler pipe and it was tight so I pulled the injen off and put all my stock **** back on... runs like a champ again but it still blows my mine. I am going to have a nice little talk with injen today.
#36
You can call Injen and complain but my bet is with what Warrtalon said about 10 times, some kind of problem with the way you had hooked up your BCS lines or the plug itself.
Also just to double check with what I think, when you did have the problem of only boosting to 12 psi, what did you boost gauge read when the car was at idle, how much vacuum?
#37
#38
Well, I told you BEFORE you bought that and the APS bov to spend your money elsewhere on things that actually make the car faster without causing any problems. You already knew what mods to get and not to get, but you went for the bling anyway. You didn't so much waste your money as you ignored sound advice. And, as much as I hate to say it, the Injen stuff does work - meaning, it does not randomly cause boost problems. Tons of people have it and have no problems at all. They just don't give $400 worth of performance. A flash and MBC would be less than $400 and give 30-40whp.
#40
Originally Posted by TTP Engineering
Then the coupler was likely leaking at the BOV or between upper and lower pipes.
It is not rocket science.
That all fine and dandy but when I put all the stock piping on it runs fine included with the stock air box.... BUT when I take the stock air box off and put the injen filter on with all the stock piping etc then it runs like **** again..... something isnt right and it has to be with injen
#42
It's improper install. Plain and simple. Don't take it the wrong way. It is what it is.
I run the Injen intake and hardpipes for the record.
Then where could the problem be? Right now all the stock intercooler piping, intake piping and what not are on.... ok I can drive it right now and it hits 20 psi. Then I take the stock air box off and just put the Injen air intake with the adapter for the filter and MAF on the stock intake pipe with all the stock intercooler lines and I only hit 12 psi....... I dont get how it is fine right until I put the injen filter on...... and ideas?
#43
You have to put the vacuum line from the BCS to the small nipple on the bottom of the injen pipe. (this may be your problem)
You have to put the line from the crankcase to the larger nipple on the INJEN pipe.
#44
