Eboost-2 ?
Eboost-2 ?
I did a search and didn't come up with too much info on this. I'm wondering if its worth all the hype they say.
Basicly is it worth all the extra cash they want vs. an MBC?
The fact that it has a tach and secondary output to controll n02 or Alky at a set RPM is pretty sweet.
Just looking for more info
I have it in my car, unfortunately could never get it too work right, it would either drop boost in the middle of 3rd gear or towards the end of 4th. I was on the phone with turbosmart for at least a total of 5 hours trying different settings and stuff. I eventually just went and bought a forge mbc. Now I'm using the Eboost2 as digital boost gauge.
neat item.
I have it set up to trigger lower boost if my WI system shows a fault.
first, a ground is closed when 10 psi is hit which triggers the WI system, second it receives a ground when WI is working which allows the eboost 2 to step to the next map (which in my case is a step to max boost)
anyway as you see it can trigger or be triggered or both. besides that it can do a multitude of beyond me boost control functions.
BoostWhore
50
Sep 9, 2006 03:46 PM
