TC howling????
well i Stopped payment on the check I gave them on as down payment of $1500 so if they say there not giving warrenty, I'm using that money on upgrading to a stage 2 Transfer case. If it cost me $500 more out of pocket for something that won't brake as easy I'm all for it. Also I ran the check engine light at autzone and it's comming back as P0300 Random/Multiple cylinder misfire detected. That sucks are the coil packs bad now????
[/QUOTE]Also I ran the check engine light at autzone and it's comming back as P0300 Random/Multiple cylinder misfire detected. That sucks are the coil packs bad now????[/QUOTE]
After speaking to Shepherd at great length last date, he told me about some of the causes of the P0300. One was of course the coil packs $u*k on the Evo, waisted spark system, Second was something having to do with the harmonics from the transmission being transmitted as a misfire and third was the gap on the spark plugs. If you want to get rid of that stupid light you can do one of the following: Upgrade your ignition system (HKS DLI or BR Coil on pack) or do what I had done prior to my EMS, get a Creader from Ebay or Vishnu.
did you change fluids in the TC? mine whined for a bit, then changed fluids in it. and it went away all together. Then i called shep, and got a built one, cause i was scared it would come back. lol.
YogSaahoth
Aug 2, 2008 12:41 AM
RalliArtEvoVIII
Apr 9, 2005 01:06 PM
