Part numbers to the 5th gear grind TSB-04-22-003REV
well, i guess do this.
drain out the stock fluid into a clean bucket and put in 2.8qt of syncromesh. do syncromesh first since its only $6.99 a quart and can be found at your local autozone store.
if the grinding persists, put back in the stock fluid. can u do the work your self? it is VERY easy and u dont need to take out the undertray.
My dealership was nice enough to do this TSB on my 03' evo over the weekend. They replaced all my synchros, pressure plate, throwout bearing, and surprisingly the clutch! What a difference it made. I no longer get the decceleration noise, clutch chatter, and my 5th gear no longer grinds.
Zerofour1223
Dec 19, 2013 10:30 AM
Last4G63
10
Aug 23, 2007 03:29 PM
