Raise the fuel pressure
Supposed you have enough fuel from the pump for your whp at ANY fuel pressure, steel braided fuel lines, and a fuel cooler,
is there any gain in power in raising up the fuel pressure to the maximum you can, without modifying the afr, but only for the better fuel atomisation, shorter injection duration and better injection timing ?
Thank you.
Thank you.
