3076R turbo 780cc injectors
3076R turbo 780cc injectors?
3076R turbo 780cc injectors are these a good choice.I plan to use race gas sometimes.I see people using 680s and up on this turbo.I will be using DYNOFLASH for tuning.
THANKS
THANKS
Yes, that will work just fine.
THANKS
THANKS
The x80 injectors typically flow like x50 injectors, so assuming 750 cc/min, 43 psi base pressure, .76 specific gravity, and target AFR of 11:1, they will support 55 lbs/min. Which i believe is about all the 3076 is rated to, so you should be right around 100% IDC if you ever max the turbo out. Works for me Using race gas SG of .724 (varies with the brand and type of fuel) and target AFR of 12:1 you get a little more headroom, about 2 lbs/min or 4% IDC.
I NEED BOOST
May 11, 2014 08:11 AM
Inprogress
17
Mar 2, 2008 01:42 PM
