Benchmark This Settup Vs. The 1/4 Mile Time So Far Achieved
Originally Posted by evodave
should be faster....32 psi with a decent tune , flat shifting, full street tires, well setup suspension with no alignment, gt35r (.63 backside), we went 10.5 at 135.5 mph .....even if we changed nothing else i would say with a 50 shot and 3 more psi i should prolly hit 9.8-10.2 at 140 ish mph..... btw we run low 1.6 60fts. btw you need to rev to 9,500 in 1st and 9k 2-4 gears...and get a triple carbon clutch so you can flatshift that helps TONS.
Dave
Dave
Woh! 9,5 RPM in 1st, and 9K in 2nd-4rth, that is normal around here? Because Im only reving the car 8,5K in all gears.
Location: driving the 10 second beast in ohio or running lightmods.net
i did 8500 rpms with the stock motor (besides cams and headbolts) to be able to go through the traps in 4th gear at 129mph LAST year when i was running pump gas and meth. if you have a built motor and head you will be ok as long as your tuning tables are setup for that rpm
