ATP GT3076R - Impressions
Old Sep 19, 2006, 06:18 AM
  #136
Az3ar's Avatar
Originally Posted by scorke
mostly from being a 9.
Scorke
yea yea yea...
It will make more power because he used his head and made things work better, because he does not flam and waste his time talking trash and of course because his name is not scorke.
Old Sep 19, 2006, 08:39 AM
  #137
scorke's Avatar
Wow Az3ar, that was rich and compelling.
Scorke
Old Sep 19, 2006, 08:55 AM
  #138
Doogie Howser's Avatar
Originally Posted by Az3ar
Just for the record, I am keeping my EVO stock because it has enough power for me to make circles around your *** and lap you ( I have no doubt that I will crush you on the track)
Good to know Michael Schumacher....
I didnt know a stock evo ix would crush a pretty much race prepped evo 8, you learn something new everyday from evom.
Old Sep 19, 2006, 03:39 PM
  #139
SmokinJoe's Avatar
I've seen a Miata whoop up on an EVO. It's all about the driver. If you cant master the tool, then what does it matter how sharp it is?
Ok - back on point. 18hrs and counting. This is what I am going to do - so speak up now if you have any objections. I am not going back a second time.
We are going to tune the turbo on 93oct, and at the same boost level as my baseline graph. This process could obviously take 5-10 dyno runs. The last setting we choose (which may not result in the highest peak numbers - but best overall curve) will be the end result @ 93oct. I will overlay this graph against my baseline.
Next we will retune the turbo for 100oct and 26psi. Using the same logic as the first test - and overlaying on my 382wtq curve.
In the end we'll be able to compare the ATP turbo to the stock IX turbo - at the same boost levels, in basically the same conditions - AND at two different stages, high and low boost.
Any objections?
Old Sep 19, 2006, 04:10 PM
  #140
scorke's Avatar
^Sounds pretty good. Couldn't think of a more fair or controlled experiment in terms of outside variables(tuner, weather, fuel,boost) should tell us a lot about the kit. I think you must also be one of the first to bolt this up to a IX, best of luck!
Doogie- Seriously.......I actually just bought all of these shiny things so that I can put the stickers they come with on my car...... not because they help performance in any way shape or form. I PM'd Az3ar and asked him for his laptimes at Roebling Road as I will be going there this weekend his response- "Kiss My ***"
Scorke
Scorke
Old Sep 19, 2006, 06:55 PM
  #141
SmokinJoe's Avatar
BTW - I thought I would share this. Do you know why ball bearing turbos are so bad ***?
B/c you can hear the turbo continuing to spin long after the car has been shut off.
Way cool!!!
Old Sep 19, 2006, 08:49 PM
  #142
scorke's Avatar
My 3076R spins for about 2 minutes after my turbotimer runs at idle for a minute.
Scorke
Old Sep 20, 2006, 03:38 PM
  #143
SmokinJoe's Avatar
Results?
Go here
https://www.evolutionm.net/forums/sh...37#post3491337
Old Sep 21, 2006, 08:27 AM
  #144
Az3ar's Avatar
Amazing
Old Sep 22, 2006, 06:45 AM
  #145
CBRD's Avatar
not sure if this was answered...
did you use an inlet from atp..... or something else?
cheers
cb
SmokinJoe
For Sale - Wheels / Tires
Jan 5, 2007 01:50 PM
SmokinJoe
Dec 27, 2006 01:01 PM
SmokinJoe
For Sale - Cars For Sale
17
Dec 11, 2006 02:14 PM
SmokinJoe
191
Nov 26, 2006 07:43 PM
2SloEvo
Aug 24, 2006 07:04 AM
Quick Reply: ATP GT3076R - Impressions
