A little too much oil.
Old Jan 10, 2007, 08:33 PM
  #31
dubbleugly01's Avatar
overfilling your oil is bad, bad, bad.... You do NOT want your oil level so high that the crank turns through the level of oil in your oil pan as others have mentioned. A crank rotating at 3000 rpms can whip up a lot of foam. That will create air bubbles in your oil, and cause engine failure shortly thereafter. Too much oil is just as bad as too little oil. Keep it between the marks on the dipstick. The important thing is to keep it between the high/low marks. If it only took 4 qts. during an oil change, you probably didn't get a good drain of the old oil. But don't force any prescribed amount of oil during an oil change if it puts you above the full mark. You'll be asking for trouble.
Old Jan 22, 2007, 08:30 PM
  #32
Lancerevoate's Avatar
oil drain procedure
It's easy to drain off if you overfilled, just untighten drainplug while keeping slight pressure against it, you can regulate by adjusting pressure, let flow into oil drain pan and retighten after desired amount is drained out, no mess..... oil capacity seems to be about 4.7 qts....
I regularly overfill the e36 m3 by 1/2 qt when headed for the track because of the oil starvation issues on long hi speed hi g corners, not too sure about whether the evo can handle overfill.
Old Jan 23, 2007, 01:23 PM
  #33
Kayaalp's Avatar
Originally Posted by Duby
does any regularly have to add a half to full quart after 2k-2.5k miles? I know I do as well as some of my friends and others in the area I've talked to . . . who's eveo doesn't sip a lil oil?
Looks like you should have been more careful during the break-in period! My 2003 Evo doesn't burn a drop of oil, even though it's got dozens of track days under its belt. But I was absolutely **** about break-in.
Emre
Old Jan 23, 2007, 01:25 PM
  #34
dL_EVO's Avatar
Originally Posted by boostedwrx
^ ditto. I check my oil like a crack addict too, just to get a good feel for where its at under what condition ie- cold, warm, after a long or short drive, etc. I've never used more than 4.5 quarts.
LOL! That is a good saying!
I check my oil like a crack addict!
Old Jan 23, 2007, 02:24 PM
  #35
evolution31's Avatar
The Mitsubishi shop manual says that the Motor takes 5.5 Quarts of oil so I think you will be OK.
Outlanders
Outlander Sport
18
May 23, 2021 09:11 PM
idiaroi
Oct 25, 2015 02:34 PM
5speedwtneed
11
Jul 5, 2013 11:57 AM
snow
Jun 19, 2013 07:51 AM
DimitrisIX
Jul 24, 2007 05:30 PM
Quick Reply: A little too much oil.
