David Buschur's switch to the "big" turbo....
#157
Originally Posted by davidbuschur
Made an additional 50 whp with the car yesterday with our new fuel system in it.
How about running it with the tubular header now that you have more fuel available, and see if that gives you better numbers than the cast manifold?
#158
The car's power with the GT35r was limited from the fuel system. The single pump we have made 542 whp on my car. After installing the twin pumps I was able to get to 590 whp.
I've done testing already with the headers. Not worth the change. The car has already gone 9.97 at 142 mph with a 1.60 sixty foot time on radials.
This turbo kit is available, it is $2995, complete.
#159
What is the best way to control the new fuel system with a stock ECU? Also what about tuning since you'd be making a huge jump in fuel pressure when the second pump kicks in?
I'm nearly at a point now where I need to consider this upgrade.
#160
Sorry for the off topic question.
Are you using the FP 3575 CHRA? Or are you just using the hotside housing?
Now I love my 3065 kit and would recommend it to everyone since the power keeps on coming but sooner or later it wont be enough for me.
#161
I am using a GT35r cartridge with FP's turbine housing.
Malibu, best way to control it is going to be a pressure switch if you are using the stock ECU. Unless you can come up with a way to trigger a relay from MAF. I have not looked into pressure switches yet, I'd like to find a good 20 psi switch.
#162
Creating a module to trigger off MAF frequency can be done.. Its just not a weekend do-it-yourself project..
Another possibility is to look closer at the 2003-2005 Intercooler sprayer maps, and utilizing the relay for that instead.. the 2005 obviously isn't wired for the sprayer, but the output from the ECU should still be there.. I haven't really looked closely at how those maps work, but its a possible solution.
#163
David Buschur
93
Sep 1, 2007 03:27 PM
David Buschur
49
Mar 22, 2007 07:32 PM
David Buschur
Aug 15, 2006 06:01 PM
David Buschur
29
Jun 16, 2006 07:05 AM
David Buschur
Aug 26, 2005 08:24 AM
