Long Rod 2.0
Long Rod 2.0
I was sitting down having lunch with my Engine builder and started thinking about doing a long rod 2.0.
Could you use a stock crank, 162mm rods and 2.3 stroker pistons?
The 12mm increase in the rod length would be accomodated by not using the 12mm longer crank and stroker piston.
Thats the same thing as the 2.1L destroker isnt it? (granted this is done on the 4G64 block)
2.1L specs: 162mm rod::88mm crank (stock)::87mm pistons (stock bore 85mm)
What is the piston size for a 2.3L? Also...correct me if I am wrong but isnt the piston wrist pin located higher up on the piston on these long rod motors as well?
no the only motor that uses a modified piston is the 2.3 stroker's. the wrist pin is moved deeper into the deck to accomodate the longer stroke and stock deck height.
No need to modify the piston on the 2.1 because it has a stock 88mm crank but 12mm taller deck.
I've seen a lot of dyno tests on NA engines where they keep everything the same but make huge change in rod ratios, going from theoretically horrible to theoretically excellent, and power gain is 1-2% on a 600+ HP engine. I don't think it's worth the attention it gets.
It has more to do with revs that the engine can handle rather than producing more HP from just a change in rod ratio. Bigger rod ratio=less side loads and slower piston speeds. The lower piston speeds theoretically allow longer dwell times so the turbo has a little longer to fill the cylinder at the bottom of the stroke. This is my understanding of it anyways....
SBR INC
Nov 26, 2016 07:39 AM
[WTB] 86mm stroker pistons
rstchris
Sep 29, 2015 07:42 PM
tupac1
17
Apr 2, 2014 07:24 PM
lonestarevo83
Apr 6, 2012 02:57 PM
SBR INC
Evo 'For Sale' Engine Internals and Drivetrain
12
Oct 4, 2009 08:42 PM
