WOW!!! What a difference!
Had my car retuned last night by Scott @ TTP-E and all i have to say is WOW!!!! The car pulls like a train all the way to redline and its unbelievable!! The car has crazy torque and improved top end.. Scott took his time and data logged the car after every pass and tuned it to perfection... The car now spikes 24.5 and it holds 23 psi to almost redline.. Was only getting 1-2 counts of knock if that... Scott said with a good pass, this car should be able to go 112 in the traps on pump!!! Might be hitting the track this friday to see what it can do.. I already ran 12.5@110 on pump back in may in the heat
Originally Posted by deadbeatrec
? should u be getting any?
Originally Posted by 2StepsAhead
What kinda mod list do you have?
Originally Posted by Evoryder
that sounds like a killer aggressive tune...
...scott is doing some magic...makes me want to get my baby hooked up by him
Damn, I'm terribly dissapointed in my traps now...I guess I didn't get that aggressive of a tune.
I'm curious to see the increase in your traps too.
Question for you though, are you sure your holding 23psi to redline? was this confirmed with a map sensor or just by looking at a boost gauge? Reason I ask is because I spike to 24psi on the street and it always drops down to 20.5 by 7k. This is using a 3bar map sensor to log boost.
