Quick- PWR/Koyo Radiator with AMS 3076 kit?!
Hi all,
This weekend i was doing some work on my car when i accidentally punctured the radiator. I figured this would be a good time to get an aftermarket one (i road race a lot) since i have to replace it and the factory ones are ~$700...
I have an AMS 3076 kit sitting here that is yet to be installed though and i began to think about clearance issues. Will the koyo or PWR radiator have enough clearance with that turbo kit?
It's for a 2006 Evo MR, btw.
I have to get this fixed as i'm going to the track in 2 weekends and need to get the car back up and running
Thanks.
Thanks.
Originally Posted by mooreboost
The Buschur half-size is always a safe bet.
I have RRE GT3076 with Koyo radiator and I still have a lot of clearance. Unless your header is within 1 inch of the radiator, i think it should be fine. If you want to, I can take pictures.
Originally Posted by fly2low
I forgot to say that I have a slim fan on the inside, though. Maybe that's a solution that you need.
I do have a slim-line fan that comes with the ams kit (which i haven't installed), but i just want to make sure the actual turbo or wastegate outlet won't hit it somewhere whenever I install it..
Thanks
Actually, this could be your solution:
A picture of an AMS car with a GT42 turbo in it. Look at the right bottom corner:
https://www.evolutionm.net/forums/at...chmentid=96520
Originally Posted by saiyanzzrage
how about calling ams
I would if they were open. And being that they are vendors, i'd like to get some customers views as well. Belive me though, i will be calling them as soon as they open tomorrow..
i'm fairly sure that the normal ams kit has pleanity of room for aftermarket larger radiators
i know for a fact that buschur kits dont have room for thicker radiators and can only be race with a stock radiator because the tial 44mm is in the way.
i think only buschur kits have this problem. and of course kits with gt42r turbos
sykou
Lancer Aftermarket Forced Induction Tech
15
Mar 20, 2010 04:06 PM
Voltex9
Oct 28, 2007 02:13 AM
