Denso Fuel pump part # ?? 255lph?
dude why are you posting the same question 3 times ?
if someone tells me the part # on top of this pump i can tell you what it really is. i sell denso pumps & the highest flowing pump available in the u.s. from denso is the supra tt pump.
this vendor is probably quoting this rating, but not mentioning the higher voltage & pressure it takes to get it to that flow rate........
Here are some info on the denso pump, with pics and flow chart.
http://mkiv.com/techarticles/fuel_pumps_test_2/
is this for me ?
Originally Posted by turboDan
Alot needs to modified to get the Supra TT pump to fit.You may want to think about purchasing a new pump housing before doing this as once you begin to modify so that the pump will physically fit,then the stock pump will never be useable in that housing again.
You must Remove the Filter assembly that is part of pump housing or it will not fit(and I dont mean the "sock"filter at bottom of pump).I have done this to an extra housing so Yes,I have done this and it is not a Butcher job but it is not by any means a "drop in" and did I mention that the wires that power pump need to have connector cut off and EyE ends crimped on.
Originally Posted by trinydex
is the modification at least straight forward? how much is the extra pump housing?
oh geez... what's hte max hp rating on the 210lph pump?
