Denso Fuel pump part # ?? 255lph?
#91
The Walbro whine is not nearly as bad as I thought it would be. I only hear it when the car is idling at a stop with the A/C off, and its not an annoying sound.
#96
Weird thing is, there should be a market for this new canister (that can house the supra pump) and wiring harness - especially now that the oem fuel canister is discontinued. It doesn't take a rocket scientist to build one, anybody got hookups w/ cnc shops that can machine out a new lid?
Note: nevermind, fullblown thread - would be have been great if they made another one supporting the supra pump though
Walbro's suck, the SRT-4 Mopar Stage 3 owners routinely replace theirs every year (comes with the kit).
#97
Does anybody have a supra pump prepped for evo install for sale. I'd like to receive it and get a tuner to install it after removing the old pump housing. I dont believe the 245 lph will suffice for running 27 psi on an fp red turbo 450 whp. If you think it can let me know, if not send me a pm if you have the pump available. I'm not interested in walbro
#98
The 60 mm Supra pump will not fit in the molded plastic Evo stock fuel pump housing. The only way that you can use the 60mm Supra pump is if you use an aftermarket housing like a Full Blown with the appropriate lower supports.
You can do the calculations on a RED's fuel use to determine what you are comfortable with for supporting fuel system mods. It depends on what fuel you are running as well...
#100
Probably not. It depends on whether you have the fuel system joining the pump's flow in serial or in parallel, what you use to join the pump flow (T-joing, Y-joing, low angle Y-joint), the fuel line size, the wiring of the pumps, and a variety of other factors.
AMS did a very nice fuel pump test awhile back which showed the general effect of some of these variables with different pumps. You might read that and be able to reach some general conclusions.
#101
I'm thinking of powering each of these pumps with their own 30 amp capable wiring circuit and having them flow, in parallel, through their own stainless steel fuel supply line leading into different ends of the fuel rail. If they don't share wiring circuit or flow through the same line via a Y joint, I'm thinking their performance shouldn't be compromised...or so I think
Perhaps to improve the performance of both pumps further, I can use a kenne bell voltage booster to push up the voltage supply to each pump to 16V.
68wsteve
Dec 4, 2010 08:33 AM
tama_mog
For Sale - Cars For Sale
Sep 9, 2005 08:10 PM
Megadeth2118
Lancer Aftermarket Forced Induction Tech
Nov 1, 2004 02:36 AM
