Getting compressor surge & part throttle bucking in high gear
Having 2 problems here. The car is equipped with a GT35r on a stock block/head with the stock metal MR BOV. When driving on the highway in 5th gear during light/part throttle movements I'm bucking a little.
I 'think' it's due to the BOV being too stiff to open up enough at part throttle and let the larger amounts of air the 35r produces back into the MAF pipe. Does anyone else have this problem?
My other problem, which I don't think there is an easy solution for, is compressor surge in 5th gear. It seems the stock head doesn't like to flow the amount of CFM a 35r puts out at only 3500 RPM, lol. My compressor cover is the 'type S' with the ported shroud but it still surges. I was thinking of upgrading to an electronic BC so it will only let me boost x psi by x rpm. That way in 5th gear I could smash the gas and not have to worry about pedeling to get around the surge like I do now. Anyone have have any more input?
Originally Posted by AlwaysinBoost
that is the one I have....
that is the housing I have. I thought thats the one you were talking about.
From: City O Sin, MA...the not so sinish part though...
Both housings help to fight surging. The one with the slots is supposed to work much better than the bullet style porting. So your givin it another shot huh? Glad to hear it .
There are only 3 ways to really stop the compressor surge in high gear:
1) Dont try to floor the car at low RPM in that high of gear
2) Put a larger turbine housing on the turbo.
3) Try to "clean up" the route for the air from the compressor outlet to the intake manifold. Any restriction in this region will make your car operate closer to the surge region.
You forgot one very important cause . . .
Many reported surging issues are caused by tuning issues, not hardware issues. Many of us running similar setups have no issues at all, despite having virtually identical hardware.
FYI
FYI
Stubbie68
Dec 19, 2015 05:21 PM
JDMevoBOOST
71
Jul 25, 2008 05:54 PM
jcsbanks
12
Oct 29, 2007 02:21 PM
broddey
22
Feb 2, 2006 08:32 AM
