adjust shifter cable?
Old Oct 14, 2006 | 02:40 PM
superflyevo's Avatar
is it possable to adjust the shifter cables
in having a hard time getting the car in 2nd geat
some times it just will not let me in gear
its not the clutch i know that ,i could be sitting in the driveway
and it will slide right into 1st gear then ill try to put it in 2nd and it will jus not go in
it feels like the syncro is not sliding all the way into the right spot well let me know
Old Dec 28, 2006 | 10:57 PM
daisaw1219's Avatar
bump same problem here
Old Dec 29, 2006 | 06:25 AM
EVO8904's Avatar
I was having a really hard time getting into some of my gears too. I bought some Buschur Racing shifter bushings and my car shifts great on. Buschur is selling them on here for $24.99 shipped.
Old Dec 29, 2006 | 01:39 PM
i already have them
Old Dec 29, 2006 | 05:06 PM
TVA's Avatar
TVA
Tranny fluid?
Old Dec 29, 2006 | 05:16 PM
sonicnofadz's Avatar
There is nothing to adjust. The cables do not have threaded linkages like they use to have on the DSM's in the past. If you are having a hard time getting into 2nd gear, this is more indicative of a synchronizer problem inside the transmission. Check the transmission fluid level and maybe try switching to Pennzoil synchromesh.
Old Dec 29, 2006 | 08:10 PM
Danny23's Avatar
i doubt its the fluid. If its only second gear then i would think syncro also.
Old Dec 29, 2006 | 10:10 PM
jrsimon27's Avatar
but if it would be the syncro then it would grind when going in check if you have air in your clutch system first!
Old Apr 4, 2008 | 08:59 PM
timmiii's Avatar
The 6 speeds do allow a adjustments in the cable system. There's clips never the shift lever selector and the clips can slide up and down, that's how it is adjusted.
Old Apr 5, 2008 | 06:19 AM
BiFfMaN's Avatar
Make sure there is nothing on the cables or the Armature on the tranny. My car was hard to shift into gear till i noticed that a hose got pushed down on the armature...kinda blocking the shifting action. The New UICP i installed lowered this pipe just enough to cause this...a simple hose trim fixed the issue.
Old Nov 6, 2011 | 09:48 AM
mrfred's Avatar
Bringing this thread back from the dead... Has anyone had any luck improving shifting of the 6-speed by adjusting the shifter cables? So much discussion about notchy shifting, but no posts about trying to adjust the shifter cables?
Old Nov 17, 2011 | 04:20 PM
newbie1989's Avatar
did you get this sorted? im having same problem, did you find out how to adjust the cables and did this ix it?
Thanks in advance
Old Nov 17, 2011 | 05:33 PM
mrfred's Avatar
Thanks in advance
The adjustment is described in the FSM. Looks straightforward, but too busy to try it right now. Perhaps over the T-Day holiday I'll try it.
Old Feb 16, 2012 | 10:26 PM
JDMevoBOOST's Avatar
Anyone ever do this?
Old Feb 16, 2012 | 10:52 PM
fasolxpl's Avatar
iim having the same exact issue and i got the 6 speed!
Quick Reply: adjust shifter cable?
