My car "Grenaded"!! What let go??
#121
Hey Smoked:
Tell the medics to put the paddles to it and shock it back to life...
I got mine all back together...again. I'm ready to roll down to GA for a tune anytime you're ready.
#122
Originally Posted by WhiteEvo05
Hey Smoked:
#123
Here is the first photo!!
Here is the dammage in my transfer case! the "yellow"area is SMOOTH, the "blue area" is how it should look, with "splines". Going back up to TRE next week, should be mobile SOON! :headbang
#125
#126
Originally Posted by badhabit90
ewwwwwwwwwwwwwweeeeeehhh!!! dat dun derr is some shiat billy bob.welp, drank up sonny git er dunn and back on thuh roads
#127
Does TRE have an improved design or just going back with stock parts? Was it just driveline shock from a hard launch on a sticky surface?
#128
OUCH!! I say, dont go on a VHT prepped track, that's my guess, or the many drags/autox I have done. Maybe 25 drag runs and 3 autox's. plus the Light to light stuff. And another thing, maybe I shouldn't have let my nephew drive it anymore! Just an update.
Kevin,
Not only did you strip those splines and sheer the snout off the other end of the front diff you also managed to crack 9 gear teeth on the ring gear.
What clutch are you using?
Kevin,
#129
Kevin,
Kevin,
So basically you snapped the whole diff in half as well as rip a good chunk of teeth out of the ring gear....
Man you just have to put pics of that kind of destruction up
#130
#131
Another thing, when I was strapped down on the dyno at AMS, they were concerned about the noise/vibrations at WOT, and they said "You better get your propeller shaft checked", as they said they were sure there was a problem with it. Could this have been what they were "feeling", the TC on the way out? I don't know where the propeller shaft is, just curious!
#133
Kevin,
Kevin,
when going to a vht prepped track you should run more air in your tires just to get some wheelspin and avoid this things sorry to read this friend and good luck
#134
You got me curious too smoked..
A quick Google reveals it must be related to the drive shaft or is another word for it....
Take a gander at this photo piece:
#135
