View Poll Results: Which center diff is better for racing, and why?
Viscous Coupling - please explain why.
35.29%
Active Center Diff - please explain why.
11
64.71%
Voters: 17. You may not vote on this poll
VCU vs. ACD - need input
Hi All,
Please vote in the Poll if you have experience racing BOTH an EVO with the VCU center diff, and the ACD unit. Please give feedback on both, specifially which you feel is better and for what reasons. Here is why I am asking for your input.
I am building a P.A.M - Project AutoCross Monster. I currently have an '04 USDM EVO with the Viscous Coupling Unit (VCU) center differential. I am trying to decide if I should switch over to a newer EVO with the Active Center Differential. I will admit that I have never driven an ACD car, but I still feel that sticking with the VCU is the best course of action. Can you help me change my mind . . . or reinforce my thougths that the VCU is best??
My reasoning that the VCU is best (for me) is thus:
Currently my car is set up to power oversteer in sweepers under accelleration, and everything seems to work well. I have trouble sometimes with spinning the inside front tire (even with a Quaife front LSD). Don't know if any of that matters, but I thought I would throw it out there just in case.
Thanks for any input you can give!!
EVOlutionary
- completely mechanical - it is in simplest terms a diff with the two sides connected with Silly Putty. It should react the same every time and be very linear with changing grip situations, smoothly transferring power from front to rear.
- light weight. At least lighter than the ACD and it's pump and everything else.
- I can keep my IC sprayer, which running 400hp on a stock IC I may need!
- cost - for me to buy an '05, swap all my parts, then sell my '04, I would be facing at least $5000 expenditure just to gain an ACD.
- possible reprogramming of unit - if anyone figures out how to make it better
- ALUMINUM ROOF - will cost $$$$ to swap an aluminum roof onto a VCU equipped car
EVOlutionary
I have an 03 with FLSD. The ralliart unit made a HUGE difference but it still doesn't handle as nice as the ACD cars I have driven. I was under the impression that ACD really didn't do much but after driving one it definately controls the delivery of power to the wheels better than straight LSD front and rear. Also, go test drive a stock 9 once. Hands down its the best spooling and handling evo of the bunch. I had the pleasure of driving one and a medium speed track with tons of tight corners......after driving the stock 9 (less alignment and race pads) I didn't even want to get back into my highly modded EVO.
I'm not sure if all of that can be attributed to ACD or if other improvements such as suspension and weight reduction do more than we suspect but the 9 is a much better car than my 2003 on a low to medium speed course.
Honestly....I don't think it's worth it. Your suspension setup and frt and rr diffs is going to dictate the balance of your car more than the ACD, IMO. A few weeks ago we had the chance to drive 3 different evos back to back, here is a quick results summary.
BSP 2003 Evo 8 w/RS frt diff and Tein RA's = very balanced and handles very well
SM 2005 Evo8 w/revalved JIC's = handles like crap and won't turn irregardless of ACD or not
SM 2006 Evo9 w/Vishnu Ohlins = handled quite well despite extremely poor alignment, did not feel as balanced as the 03
Time results, 05 was slowest, 03 was 2nd by about 1/2 sec and 06 was quickest all of the cars are pretty well prepped and were contenders at the Pro and Devens tour. I personally would have know the cars actually had ACD if nobody told me, it was simply transparent in my eyes. The Sti however has an almost intrusive system with the DCCD.
Read this thread, this should answer what you want to know about the ACD, and why it's better.
https://www.evolutionm.net/forums/sh...ht=acd+answers
lathiat
Nov 24, 2015 09:17 AM
RaNGVR-4
GSC Motorsports - Charleston, SC
Sep 19, 2007 09:17 AM
EVOlutionary
67
May 15, 2007 03:25 PM
