Loud exhaust pops in between shifts?
So ever since i got the Walboro and a re-tune, everytime i shift real fast, the car gets loud backfires...I was at the track last friday and everyone told me i was shooting orange flames out when i shifted from 1-2 and 3-4..Whats the cause for this? The car has a 11.5-11.6 A/F across the board
Are you flatshifting 1/2 and 3/4?
If so then thats the reason.
High RPM, the ecu first cuts the ignition when it initially hits the limiter. Therefore overfueling occurs. Hence pop and flamage.
Originally Posted by EVIL_EVO_VIII
Do you mean powershifting? If so, the answer is no. I lift on every gear
I'm only guessing here, but perhaps the ecu isn't reacting quick enough too shut off injectors when you lift off, hence a little overfueling is happening since they're firing flat out at high rpm.
Only a guess though...sorry.
Originally Posted by spdracerut
It's just a backfire. Generally from any combination of running rich and having a big exhaust. Not having a cat makes it more pronounced.
