Aftermarket clutch and 2-step
how's everyone doing? i have a question regarding aftermarket clutches and 2-step. If i were to take out the pill would i "safely" be able to use 2-step with an act hd clutch? i understand how the pill slips the clutch a little, so without it and a hd clutch will i risk breaking s*it with 2-step? if that's a problem, should i just leave the pill in with the act hd? can anyone with experience plz chime in. thnx in advance for everyone's help
silva
silva
silva
silva
When launching properly, you are not dumping the clutch, so the restrictor matters little. I saw no change in how I launched the car with it removed, and it did not feel any different at the pedal. I use a 5500 rpm two step with about 8 pounds of boost. Taking the restrictor out will however allow the clutch to engage faster when shifting, since you let up on the clutch as fast as possible in this case. It does nothing for getting the clutch pedal to the floor, contrary to popular belief. It's spring loaded and gets out of the way when the pedal is traveling in the downward direction. And indeed, I saw no difference in this area either when I removed mine, as expected.
Essentially it will not matter for launching unless you side step the clutch like an assclown, in which case you will potentially get the driveline breakage you so richly deserve.
silva
silva
And by safely I mean using the 2step launch technique - advance search launch and SmikeEvo. I have written how to do it more than a few times.
Not safe is just dumping it. So read up on the tech.
Icecream - youscream - weallscream...its been a long day... 2step is the factory installed code in our ECU so than when the clutch is in, and we are at 0 mph (no forward movement) the ECU will bounce at 5k when you have the clutch in and you foot all the way down on the gas. This feature is on 05s+. However the 03/04 do have this code, its just set way beyond the redline - to fix/get it, either get a flash and have it programmed back in, or get the EcuFlash software and DIY. This nifty function allows us to build up 8-11 psi of boost at the line i.e. less lag at launch.
Here is my 2step tech.
https://www.evolutionm.net/forums/sh...12&postcount=3
Originally Posted by vwjeff
Removed the pill and put on a BR stainless line and my clutch is in...or out.
It will help but it will still slip, I think anyway.
Originally Posted by icecream6
ok this is when i feel like the biggest noob but what the hell is the 2- step ..
did a search and it came up with anything and everything that dealt with the #2
Crimson316
Jun 19, 2015 02:49 PM
infinite3k
Jul 22, 2010 12:54 AM
2StepsAhead
Jun 9, 2006 05:29 PM
