Evo IX MR / RS OEM Blow Off Valve: is it ok?
I own an american IX MR with some reworking... It gives 360 hp with 1.6 bar peak pressure and 1.4 constant.
I still have the OEM aluminium BOV. I know the old plastic Evo VIII BOV was worth very little, and leaked.
Does the new alu one correct this problem?
Should I get an aftermarket one, and which one (recirc, anyway)?
This JDM DV has a loyal following, but in my case at least, it hasn't performed up to expectations. Maybe my unit just isn't a representative example...I don't know. Anyway, I wish I'd purchased a different recirculating diverter instead.
This thing(JDM DV), at least in my experience, which apparently varies from that of the others, starts to bleed-off at about 10-11 psi. It's nothing major, but it is evident that the piston is lifting off its seat a bit early. This just slows turbo spool-up down a bit much for my taste.
Now, this is with a ported housing, titanium wheeled JDM RS turbo, cams advanced to +2/0, WGA preloaded really tight, anti-lag, and initial ignition timing retarded a bit for quickest spoolup. Other's results may vary, but I found the thing to be a bit wimpy. Now, it may be that it tends to hold decently(albeit partially open) at higher boost levels up to around 25#, but I wouldn't know since I've never boosted my car over 23# on its pump gas diet.
Anyway, in my case at least, and I am a quick-spool fanatic, I found that it does slow turbo spool down more than acceptable. I haven't made up my mind, but next time I will try something different(but, still recirculating), like either the Forge RS DV, a crushed 1G, the Works/GFB, or the Dejontool's modded DV.... once I save up enough lunch money.
Originally Posted by whitey4d
I would crush it like people do to 1G valves, same effect and wont cost u any money.
Sparky, yours must just be faulty, because that is not normal for any JDM MR DV. I've pressure tested many, and they don't open until ~25psi.
I am gonna have to go back and retest it again. My pressure testing is quite scientific. Since if you install the DV valve backwards....it doesn't open at all, I just compared spoolup with backwards installed vs. correctly installed. This is all done, of course, with certified S.O.P. instrumentation.
Sorry for the OT and the thread jack..
Many people have crushed the JDM MR DV, but it's not necessary. All the ones I've tested to 25psi were uncrushed, except for one. I didn't try to test it above 25psi.
The whole bov line tapping is a possibility, and people have made that reference in the past, but I'm not 100% sure.
FS[West]: OEM EVO 9 IX BOV Diverter valve
fugiwara
Jun 24, 2016 04:24 AM
FS[West]: OEM EVO IX metal dv bov diverter valve
fugiwara
Jun 1, 2016 02:13 AM
WTB[West]: Evolution IX MR OEM Cubby & Shift Knob
ITOzann
Sep 24, 2015 01:22 PM
reboundicon
For Sale - Part Outs
10
Jul 8, 2011 05:24 PM
