Problem: BOOST Spike + Fuel Cut.
Uh, you hit "fuel cut" then it drops to 15psi? That is not what fuel cut does. Fuel cut is like hitting a brick wall, because everything immediately shuts down. You don't just keep going at a lower psi.
This is weird. You really should have someone knowledgeable look at it and also get a tune to go with all those mods.
i dont know if i blew out smoke in the rear because my window tint from the back is pretty dark so i couldnt tell.
i will get a basic flash soon along wth a new fuel pump. i hope that should fix the problem.
