Problem: BOOST Spike + Fuel Cut.
Old Oct 31, 2006, 10:40 PM
projekt_shocker's Avatar
Wassup,
I just got done installing my 4-puck clutch last weekend and took it out for a test drive the past few days here... and i have a couple problems to bring up to you guys and see what you think about this..
When i start off and floor my car, my boost spikes up to 20-21 psi then goes down to 15 psi. when i reach 4500rpm-5000rpm my car starts to have a fuel cut.
i really dont know whats wrong with my car, but if you guys have any experience with this issue... let me know if this is a common problem to all evos? or can this be resolved by doing something to it?
I am running stock fuel pump, pump gas, FMIC, intercooler pipings, intake, and 3" TBE.
and my car is a 2003 evo 8
Old Nov 1, 2006, 06:31 AM
Warrtalon's Avatar
Yes, fuel cut is normal if you aren't tuned and have more airflow from raised boost, IC pipes, intake, exhaust, etc. Do you have an FMIC, IC pipes, intake, and TBE with a stock fuel pump and stock tune? Please say no!
Old Nov 1, 2006, 09:55 AM
YES I DO!!
Old Nov 1, 2006, 09:57 AM
Pure Playaer's Avatar
time for a walbro 255 lol..
cheap mod.. n ull like the difference!
U NEED A TUNE
Old Nov 1, 2006, 09:58 AM
whitersevo's Avatar
hmm 15 psi at 4500 rpm i dont believe that is normal either.. but you do need a tune..or your engine is going to go bye bye... I cant believe you would get all that and get no tune..
Old Nov 1, 2006, 10:13 AM
its safe to drive normally right but no beating on it
Old Nov 1, 2006, 10:37 AM
Enjoi926's Avatar
tune it, my friend has the same problem only because he hasn't upped the fuel yet.
Old Nov 1, 2006, 10:44 AM
Mad_SB's Avatar
Umm, does not sound like fuel cut... are you getting an overboost code set? Sounds more like a bad boost leak than fuel cut.
A walbro is a good idea, but will not prevent fuel cut due to overboost by any means.
To start, you should get a tactrix cable and a copy of Malibu Jacks mut logger from aktive matrix then do some logging, that will tell you if you need a walbro and if you are infact hitting the boost limiter.
Old Nov 1, 2006, 10:56 AM
Warrtalon's Avatar
Fuel cut is likely, because he has all those free-flowing mods but no tune. It happens all the time on Evos in cold weather with exhausts and no tune, because the lessened backpressure causes a raise in boost, and the increased airflow at higher rpm causes fuel cut - the ECU is set to cut boost if the MAF HZ (airflow) exceeds a preset level.
He doesn't need to log anything to see if he needs a fuel pump - that is not the reason for fuel cut. We are just saying it's not smart nor does it make any sense to have those expensive mods without having the most important mods for power and safety: fuel pump and a tune.
Old Nov 1, 2006, 02:50 PM
Mad_SB's Avatar
The reason I was giving the thumbs down on fuel cut is the 15 psi at 4500 rpm comment.
I suppose if he is hitting fuel cut due to the boost spike and subsequent load overrunning the boost limit of the stock ecu, that would pull down the boost and cause the lower boost.
I had a utec on the car before ecuflash, so i never actually experienced fuel cut, jut the overboost cel code.
Old Nov 1, 2006, 03:03 PM
nigletsyz's Avatar
a bit off-topic, but don't beat on your new clutch.. you need to break it in properly. Otherwise, you'll end up spending more $$$ replacing it in a month or so....
Old Nov 1, 2006, 03:06 PM
Warrtalon's Avatar
Mad, I ignored his 15psi comment, because I'm not confident it's actually doing that. I would have to see a MAP sensor log to really believe it, but I agree that 15psi at 4500rpm will not cause fuel cut unless there is a major problem elsewhere.
Old Nov 2, 2006, 05:07 AM
Mad_SB's Avatar
I agree War, 15 psi is a long way from fuel cut, so the op's description is very vauge.
Shocker, we need a better description of what is going on here. Are you saying that when you do not get fuel cut your boost curve spikes to 21psi gauge, then falls off to 15 psi gauge by 4500-5000 rpm? Or it falls off to 15psi when you do hit fuel cut?
What rpm are you getting what feels like fuel cut?
one thing you might try is going wot latter in the rpm range.. may sound silly, but again most of the time I have seen fuel cut due to "over boost" it occurs lower in the rpm range, very close to peak torque, since you hit peak load at that point and "over boost" fuel cut is driven by the load value.
Old Nov 2, 2006, 08:15 AM
the fuel cut happens when i apply the gas and revving at 4500-5000 rpm boost spiking at 21 psi. after the fuel cut the boost level tapers down to 15 psi. it happens when i start off from a dig and on a roll.
forgot to mention too that i have a SES light on. I will get the codes to you guys in a few..
Old Nov 2, 2006, 08:37 AM
its okay i bought a new 'used' clutch from a guy that switched over to ACT. the clutch i have has... 400 miles on it and i drove it around normally for another 150 miles.. then i just went at it a few runs. then i discovered this issue.
Quick Reply: Problem: BOOST Spike + Fuel Cut.
