Forge MBC question.
Forge MBC question.
hey so i have the forge unos on my car and it works great except, i lost the stiff spring. i was running the soft one because the stiff one was spiking 30 and holding 24 and 91 oct, owns it. so i found some race gas and was going to put the big spring in but i cant find it. is there anywhere that sells just the springs? i might be racing a modded 03 Cobra again tomorrow and id like to beat him this time. even with the boost all the way up on the small spring im only getting 24 and holding 21-22. if anyone can point me in the right direction that would be cool.
nate
nate
1 Post
Call BR and they should be able to sell you one. But I understand you need it for tommarrow. All the modded Cobra's around here are 600+ whp. But good luck to you!
I am using the spring that came with my BC and when I tighten it all the way down it spikes 29 psi.
You got me thinking what might happen if I used my other spring.
Although it won't help with your race..... drop me a line with your address and I can send you a replacment.
angel@forgemotorsport.com
We have some spare springs, so if you need one, it's as good as done!
05_EVO8_GSR
Apr 12, 2017 11:19 AM
Impulsoren
Feb 6, 2007 08:59 AM
