Buschur Racing's new 20gLT, EVO Green turbos ready to be ordered.....
Old Nov 9, 2006, 12:34 PM
  #256
midwestmonster's Avatar
Originally Posted by davidbuschur
Couple things as I am reading through all this.
The turbo rating I quoted was incorrect. 46 lb/min is what the turbo flows.
For reference, what does a 50 trim flow? Is it about the same?
Old Nov 9, 2006, 01:32 PM
  #257
Erik@MIL.SPEC's Avatar
I think 50 trim flows 49-50lbs a minute, hence the name.
Old Nov 9, 2006, 01:55 PM
  #258
l2r99gst's Avatar
The name of the 50 trim is because of the ratio of the exducer to the inducer of the compressor wheel. It has nothing to do with it's airflow rating.
At a pressure ratio of 2.0, the T04E 50 trim is rated at 44 lbs/min. At higher boost levels the compressor maps shows up to about 48 lbs/min.
Eric
Old Nov 9, 2006, 02:26 PM
  #259
So basically, this new turbo is going to flow as much air as my 50 trim?
Old Nov 9, 2006, 02:38 PM
  #260
lcakes05's Avatar
Smile
i wouldnt worry midwest, no one w/ this new race gas only turbo will be able to keep up w/ you.
Old Nov 9, 2006, 02:47 PM
  #261
kjewer1's Avatar
I was able to get 49 lbs/min out of a 50 trim typically, but hit 50 lbs on a cold night. If this turbo also flows 49 lbs/min, it is unlikely to be at any measureable dissadvantage to the 50 trim.
I've seen flow numbers from 47-49 lbs/min. The power and performance results lead me to believe it will come out closer to the 49. I really should just buy one of these things and test it (DSMlink). Anyone willing to buy it back from me at a slight discount if I decide I still need to go bigger?
Old Nov 9, 2006, 03:02 PM
  #262
Duby's Avatar
I've looked through all the pages and havn't seen a comparison or even mention of ATP's turbo that compares to a bolt-on 50 trim, for 300 bucks more would you gain anything? hp wise and is the spool relativly the same on both the ATP and green ?
the ATP has shown 485 on pump+meth, How does the LT compare to that . . . unless you have this or have dyno-ed this I guess you can't answere . . . buschur specific 450whp on what race fuel?
Old Nov 9, 2006, 06:10 PM
  #263
evo jason's Avatar
I could get past page 14, I smoked two cigarettes and was still all wound up. This is some crazy debate. David is the man, back off and show some respect. He's doing the best he can.
I'm with honda guy on the point below, a variable geomitry turbo would be a dream come true. I'll be holding my breath too...
Originally Posted by honda-guy
all this talk about the magical turbo, when are we going to see a variable flow turbo for the evo like the one being used on the new Porsche and Acura RDX. the Acura's turbo seems to be in simplest form with just a flap inside that resemble an internal waste gate, although there might be a patent on it. with these turbos, you can have the best of both world. imagine 500 whp on pump gas with minimal lag like the stock turbo. variable flow turbos are nothing new but it looks like it's becoming more mainstream. i'm going to start holding my breath.
Old Nov 9, 2006, 06:26 PM
  #264
evo jason's Avatar
My car is set on kill all the time. I find that the day that it isn't I end up running into some fool that wants to race me and I might loose on pump gas
LOL my Evo with the BR stage 1 is faster than 99% of cars. The stock Evo is faster than 95% of cars. I think anything as fast as what you drive is in the 99.99999% range.
I know what you mean though. Even time we ride in my buddy's '03 Civic SI, I see something worth smoking and wish I took my car. That's just the way it goes.
Old Nov 10, 2006, 05:25 PM
  #265
EVOMIZ's Avatar
fp green
good name
Old Nov 10, 2006, 05:33 PM
  #266
whitey4d's Avatar
Going 10's would not be a problem on the stock head and stock shortblock with this turbo. What is going to be a problem is getting the rest of the combination right and getting someone who can actually drive well enough to pull it off. The cylinder head on the EVO flows enough stock to support this turbo without a problem. The shortblock will add a minimal amount of power to the build, if any. You do the shortblock for durability not power.
The datalogs I have for the turbo are in milivolts that have to be converted to lbs/min. The laboratory test meter we did the flow testing with, I no longer have, it is at FP now. I do not have the charts either. FP just sent me an IM saying on his very very mildly modified EVO he just say 46 lbs/min.
Thats pretty impressive considering that fact a maxed out 50 trim in a T04E cover is only 49 lbs
Old Nov 10, 2006, 05:37 PM
  #267
555R's Avatar
has buschur tried the 25G compressor is this setup?
just curious about possibilities
Old Nov 10, 2006, 06:07 PM
  #268
Spaceball 1's Avatar
Mid 10's have been on first time out on two different cars. Yes both were built and both had awesome drivers.
25g they would have to have a new compressor wheel made for the reverse rotation plus a different cover
Old Nov 10, 2006, 08:08 PM
  #269
Max Power's Avatar
Sorry if this is already posted (I didn't feel like going through the whole thread) but FP has some info on a mildly modded 9:
http://www.forcedperformance.net/evogreen.aspx
Old Nov 10, 2006, 09:00 PM
  #270
purevibez's Avatar
there you go lightly modded evo with the turbo bolted on 245hp to 347hp yeah end of debate. llok forward to buying one from u david.
Quick Reply: Buschur Racing's new 20gLT, EVO Green turbos ready to be ordered.....
