Buschur Racing's new 20gLT, EVO Green turbos ready to be ordered.....
Old Dec 8, 2006 | 02:20 PM
  #481
l2r99gst's Avatar
Originally Posted by davidbuschur
One way of knowing for sure the car is making more power/flowing more air is the fact that it went lean adding the other turbo. That means it is flowing more air, as you know.
I don't agree with/follow your logic on this, Dave. Running more airflow can make you run leaner or richer, all depening on how you have your open-loop fuel maps setup. By default, higher airflow and load cells are richer than lower airflow and load cells at the same RPM. Once the car is flashed, it all depends on how the tuner sets up the fuel tables.
If you had to change intakes or filters, I can see that changing the MAF calibration slightly, which could cause a leaner or richer condition, too.
Originally Posted by kjewer1
The turbo definitely flows more air. Once I can get all the information together I'll post the results.
Kevin, I am intersted to see the DSMLink data. The turbo definitely sounds good and looks like it is flowing more air. I'm curious as to where you will see it max out and how much boost it will hold to redline.
Eric
Old Dec 8, 2006 | 02:23 PM
  #482
mcwop23's Avatar
jesus christ your dyno is a heartbreaker
Old Dec 8, 2006 | 02:25 PM
  #483
David Buschur's Avatar
Luckily my feelings aren't hurt as you all know I don't care if anyone agrees with me or not! haha
If the entire range was tuned properly most people will tune a car at the same boost level under load. So you'd have an AFR of say 11.5:1. If that entire range then goes to 12.5:1 I'd venture to say the car is flowing more air. Since I primarily think AEM and speed density sometimes I talk (type) with only that on my mind. In the case of using the AEM and speed density, you can bank on the AFR's going leaner meaning more airflow.
If every load cell was tuned properly and at the same AFR's on a MAF equipped car a leaner AFR should also translate to more air flow, you don't agree with that?
Old Dec 8, 2006 | 02:30 PM
  #484
l2r99gst's Avatar
I think AEM and speed density were the missing pieces of information.
EDIT: I just re-read this quote. I thought your said a leaner AFR would be more power, not airflow. So, actually, no I don't agree with that. If all of the load cells were tuned to a certain AFR on a MAF equipped car, and then suddenly you had a leaner AFR after a modification, then I would say that your MAF calibration/air metering was slightly altered.
The MAF is just translating a Hz value into a mass airflow value with other data such as barometric pressure and temperature. If you got more airflow from a bigger turbo, your would simply be in a higher load cell...if that load cell was tuned to the same AFR, you should still have the same AFR, even with the higher airflow.
I'm not saying anything bad about the turbo. I think it will be good...I'm interested in Kevin's data.
Eric
Old Dec 8, 2006 | 02:48 PM
  #485
HmanEVO's Avatar
I apologize if I misinterpreted what you wrote but that doesn't make sense to me. A properly working MAF should be able to sense any increase or decrease in airflow and then relay that info to the ecu to make the needed changes to maintain the AFR. The AFR should not change provided all of the load cells are tuned properly for any given amount of airflow correct?
On another note, Kevin I look forward to viewing those logs when you're done. Feel free to send them my way.
EDIT: I see Eric beat me to it and got the point across a lot better than I.
Old Dec 8, 2006 | 04:39 PM
  #486
kjewer1's Avatar
I see what Dave is saying, and he is correct, but you have to pay attention to the details of what he is saying. . We were both refering to AEM running on a MAP sensor with no change in boost.
It's all a matter of perspective, how you tune, and how the system is set up. For example, in the AEM I stayed on the same load level and got leaner. That means more airflow at a given boost, which is a goot thing. I then turned up the boost. If I had tuned for the same AFR on the next load level, AFR should not have changed. If it's tuned for another AFR, or for an unknown AFR, it will change. Same thing with a MAF based setup. In the case of DSMlink, I am always on the highest load level at WOT, which provides the advantage of giving me the same AFR and timing no matter what boost/airflow is. Any change in airflow is measured and compensated for, and AFR remains where I set it. So you can see that the result of the change in boost/airflow can vary widely based on how the system is set up.
Airflow information posted here.
StreetThisEvo
Oct 13, 2008 08:49 PM
Duby
17
Nov 16, 2007 08:36 PM
David Buschur
161
Aug 23, 2007 10:22 PM
J8dailo
23
Jan 15, 2007 09:16 AM
David Buschur
163
Oct 16, 2006 10:30 AM
