AFR 21 at Idle.....
#47
Originally Posted by BADEVO
Yeah same car that was overboosting. It's settled down now I can get it to right at 21 - 22 psi, but no lower.
I been beating my head into a wall over this scenario for 3 days now.
-Paul
#49
Turns out it was a bad DP flange. It was warped and was leaking, so no matter what gasket I put in it wasnt fixing it. Swapped the DP, popped in a donut gasket and viola....fixed my afr's at idle. Now onto other issues.
#51
Originally Posted by joeymia
at 21 your car should not idle... check your wideband
JK
It was a warped DP flange. IT was allowing "fresh" air in and the Wideband sensor downstream was picking up that clean air and thinking the car was lean.
#53
Um... I guess you missed that last post Joey ? LOL
JK
JK
#54
Originally Posted by C6C6CH3vo
So what part was leaking, the DP flange to cat or O2 housing to DP?
DP flange to the O2 housing.....
I figured the length of the thread was what threw you off Joey.
shane_evo7
Mar 7, 2019 06:49 PM
SwiftEVO
17
Jun 22, 2005 12:20 PM
