anti lag in japan
anti lag in japan
upon closer inspection of the MIVEC issue of hyper rev
it seems all evo9s cam with anti lag
can anyone confirm this?
I cant read japanese kanji
and how can i get the complete factory setup?
If you're talking about those pipes that go to the exhaust manifold then all evos snice the 4 have had this.
But don't worry too much about it, its not a flame spitting banging sort of anti-lag, its just a really passive system that dumps pressurised air into the exhaust manifold when a series of conditions are met.
Plently of people have taken those pipes off without noticing any sort of difference so don't go feeling you must have it.
ak47 -
similar but has runners going into both banks
yogi-
im just that kinda person who wants crazy things like that
can you get a complete setup from new zealand?
like how i built by EG hatch
it was all jdm things that were tough to find here in the USA
yogi-
You probably could, I seen one go for sale here.
But keep in mind its controlled by the ECU so check that the US ECU has the capability to control it, plus you need the solinoid to control the system as awell apart from just the piping and air valve.
Some names this thing goes by is "Air Control Valve", "Secondary Air System" or "Secondary Air Control System"
If you're really keen you could ask in the 'Want to buy' section here http://www.mmc.org.nz/forum/ (NZ) or over at the lancer register http://www.lancerregister.com/index.php?styleid=4 (UK)
Guys, the antilag that I know is the one that has been implemented on rally turbo cars for decades now. It is about having a 5th injector(additional injector) on the exhaust side of the turbo.
By injecting fuel in a timely shyncronized manner the turbo keeps the momemtum and maintains a fast rate of re-spool up.
The downside is the nasty sound of explosions coming from the exhaust and off course those 3-4 feet flames coming from the exhaust as well.
I am not trying to diviate from the original topic but since someone mentioned the anti-lag set up I thought that my remarks are appropiate to the subject.
Just my .2c
Carlos
Just my .2c
Carlos
the system im looking for is the factory secondary air system
which in other parts of the world have them on factory cars
it is a mild form of an antilag system injecting air into the manifold
japan and the UK have them
US doesnt but from what i am finding out
the USDM ECU has the capability to run it...
it is mild nothing like the crazy WRC setups
or what autronic can do
and you can shut it off whenever you want to
now also known as turbo assist
Originally Posted by deathtracks
I believe those pipes are EGR feed pipes if you follow the valve that hooks back into the intake side.
