knock sensor
knock sensor
would n e thing with the clutch cause the knock sensor to come on thanks
caleb
and also what would cause the knock sensor to cause fuel cut
caleb
Some aftermarket clutches produce a lot of racket. The knock sensor may hear this.
As for fuel cut, I don't think the knock sensor would be involved. Fuel cut occurs at too many revs or too much air.
A DSM I once owned had a loud lifter. Eventually this got so bad the knock sensor would pull all the timing all the time. Then my car had trouble developing enough power to pull away from a stop sign. Are you sure you are experiencing fuel cut?
well we were out in it today at wot in 4th and 5th and it did fine and some times it cuts bad like full boost then instant 0 psi then takes off again just in 4th and 5th n e one know a way to fix this will try plug wires
