Megan header+02 housing gasket question.
Hey guys,
I just got my Megan header and 02 housing in the mail from ttp. Took 2 days to get here, thanks Scott
My question is.. I researched a lot before my purchase so I know all about the header gasket. I plan on re-using the stock gasket that connects the header to the block, but what about the other side? and the 02 housing gaskets? Should I use the stock ones for everything or just the block side of the manifold?
thanks in advance
thanks in advance
Originally Posted by 03redtype-s
just got done doing the same setup and yes use the stock gaskets
yes use the stock gasket where the manifold meets up and also the gasket between the hotside and 02 housing. also when taking the stock 02 housing out soak that thing hardcore in pb blaster or something to loosen bolts up with becuase you can very easily break the studs
what is pb? Other than that thanks a lot for the help, intalling both pieces tomorrow.
Originally Posted by TTP Engineering
All 3 gaskets. Manifold to head= stock metal, manifold to turbo= stock metal, hotside to O2 housing= stock metal and you will have no gasket issues.
Originally Posted by andifidie
Thankyou, its very rare to see the seller of a product back you up and help you after you pay. Once again, always impressed with you guys. I will be purchasing ALL of my evo performance upgrades and parts from you guys!
Thanks for your support.
EVIL_EVO_VIII
11
Nov 3, 2005 11:36 PM
