Car hops in 1st gear
#31
yeah that is correct. The motor mounts are on the front, passenger and rear side. There is one transmission mount on the driver side. All of them except the driver side mount come off when doing a clutch job though. At least I had to take them off the last 2 times i did it.
#32
Originally Posted by joon
turns out, everytime you add a aftermarket clutch, you have to replace the flywheel. I had my flywheel resurfaced, and that, thats the reason why it shakes. he also noted i had a ripped axel boot.
??? Sounds like they are trying to make a quick buck off you. That is total BS. I had my OEM flywheel resurfaced for an ACT clutch and am not experiencing any of these problems. So perhaps your machine shop is inept and the flywheel wasn't resurfaced properly.
#34
Originally Posted by sonicnofadz
Maybe I am retarded? I have never removed the engine from the Evo, but I have examined the mounts, and they look exactly the same as a DSM. The shop manual also shows three engine mount locations that attach to the block. Here is what the shop manual says:
Looks like 3 engine mounts to me? The 4th "engine mount" is referred to as a transaxle mount in the Mitsubishi manual.
#36
i had that happend to me when my car used to hop in first gear..but then i bought weapon r engine dampering kit..an it work good for me..the car doesnt hop..well thats for me..
maxspeed96ct
Sep 29, 2016 06:53 AM
