Car hops in 1st gear
whenever im at a stop, and i begin to slowly let go of the clutch, the car feels like it hops. it only happens during first while taking off.
I have a racing clutch. and everything else is stock.
anyone have any idea? ive been told it might me the pressure plate, maybe a out of center clutch, motor mounts, and even internal transmission.
Fomer Vendor
I think Im having the same problem right now. But mine started out of the blue about a week ago. Feels like a mount to me, but Scott said it could be a TC issue. I need to get under it and look around. Fing annoying.
Originally Posted by joeymia
that not really normal... have someone check your motor mount especially the rear. Maybe whoever did your clutch forgot one.
to be honest with you, if you have ever raced a front wheel drive car, its feels like when you rev it upto like 4k, and released the clutch, it hops for a couple of feets..
Motor mounts are tight, i triple checked everything! One question though, when i press the clutch, and i shift into 2nd, and i give the car gas,(and let go of the clutch) i feel the clutch, slowly creep up, i adjusted the clutch like 10 times!
we;ll see.
we;ll see.
Originally Posted by sonicnofadz
If you have an aftermarket clutch (especially a twin disk) it is normal. Motor mounts (and a stiffer suspension) seem to help. You shouldn't have to disconnect a motor mount to do a clutch on the Evo.
