FPEvoGreen First Impressions
#91
Originally Posted by Pd1
Yes, I do have Denso 660cc injectors.
After some additional tweaks on the tune, I'll post up another pull for analysis.
It looks like we're reaching the limits of CA 91 octane and his given setup. At a later time we'll conduct some tests of different cam timing combos to observe, and illustrate their effects on spool and power production.
#92
Originally Posted by JustDSM
As a note for everyone. We're not likely going to see much if any additional power. The changes that are being made are more for smoothing transitioning cells.
This car should put more power than this. If I was trouble shooting this car I would do the following:
1. Ditch the intake and go back to the stock intake. You are nowhere near 400 whp which is supposed to be the number when you switch to an open intake.
2. Ditch the Works O2 housing and go back to the stock one. Port it and polish it if you want. The stock O2 housing is the best housing IMO.
3. Get 93 octane gas by mixing 100 and 91. The Evo is supposed to run on 93 octane. Running it on 91 octane with a stock turbo is bad enough. Running it on 91 octane with a bigger turbo is even worse.
4. Tune your car or have it tuned on a DYNO.
#93
your number 3 makes no damn sense... you tuned the car.... it'll work on the octane you tuned. raising octane becuase the car was "made for it" that's.... about as smart as running 93 octane all the time cuz you want inconsistent octane numbers from mixing.
i'm also glad that dynos are what you drive on all the time and i'm glad you use a road dyno to boot.
i don't understand how you people think...
the fact is he said already that he feels better, feels faster and has a bit more top than the 9 turbo WHICH HE ALREADY HAD. i can care a lot less what your car does in comparison to his... that's two different cars... good job pointing out the difference... wanna tell us the difference in license plate numbers too?
#95
Originally Posted by nj1266
I find it puzzling that you go with a bigger turbo and use 91 octane gas. What is the point of that? There are cammed Evo 8s with TBE and stock turbo putting 330 whp on a dynojet on 91 octane. This seems to be the same number that this car is putting with 272 cams, a bigger turbo, TBE and MANY other mods on 91 octane.
#97
I know you do not like dynos. You made that clear on SoCal evo. Keep tuninng on the street and hopefully you will not get your car confiscated by the police like what happened to your pal Blaze
Yeah, the car posted better numbers over the IX turbo that he had, but that is nothing to brag about considering the the numbers with the 9 turbo were barely 300 hp. Something is wrong when a car with a 9 turbo, 272 cams, TBE and LICP, Works O2, and intake only puts down close to 300 hp. This is according to the 3rd gear pull he posted on the 9 turbo TUNED.
Do you honestly believe that these are healthy numbers?
#98
Originally Posted by kimletrim
Don't worry guys...I think Pd1 knows how to think for himself. I don't think the above post is going to change his mind on the O2 housing, intake or gas used.
#99
Here's an updated tune log. Again, 3rd gear on a flat road. It may just be the cooler ambient temperature, but I'm hitting some higher load sites now. Yes, I finally changed my plug wires back to stock .
Special thanks to JustDSM for his insight on this tune.
#100
Why is your car running so little timing up top? It is only @ 8* by 7k rpm and yet there are some knock counts. Any ideas on this?
#101
Location: Work - New York, Alaska, Mexico or the Caribbean. -Home - Tx Hill Country
Also, according to people who have actually done some testing, #2 is wrong. There is a long post about O2 housings and dyno testing them by a well known tuner. Unless or until you take the time to actually test the different options, I would suggest you keep your opinion to yourself as it is pretty much worthless.
#103
Originally Posted by robertrinaustin
Come on, most everyone knows you can't compare different dynos, even of the same type. In fact, you really shouldn't compare the same dyno if the conditions are not the exact same. Your speculation as to what this car should or could make on this or that dyno is merely that, speculation.
Also, according to people who have actually done some testing, #2 is wrong. There is a long post about O2 housings and dyno testing them by a well known tuner. Unless or until you take the time to actually test the some of the different options, I would suggest you keep your opnion to yourself. It is pretty much worthless.
Would you be happy if your car with a TBE, cams, O2 housing, intake and a bigger turbo produced only 330 hp? Most Evo 8s with cams, TBE, and a stock turbo are putting 320-330 hp.
A lot of people have experienced boost creep with the O2 housing. Some have not. The OP tells us that he has boost surge. Could it be the O2 housing? Maybe. Worth a try IMO.
Since you think I am wrong, then please tell us why this car is underperforming?
#104
I find it hard to believe that both dataloglab and ECU+ dyno features are producing very close dyno numbers on this Evo by accident. Both of these program are very good programs and both of them say that this car is putting around 330 hp. The OP has posted three Evoscan runs so far and they have produced 340, 330, and 322 whp. I have kept the temp, humidity, weight, and pressure constant on all three inorder to avoid the influence of these variables.
