FPEvoGreen First Impressions
#121
Based on the information in this thread, it appears that the FPGreen
turbo is not to happy on California 91 pump gas.
At this point, I would find it hard to spend $1700 on this turbo.
There is still more testing to be done with higher octane, a higher octane tune and more boost.
#123
Originally Posted by nj1266
If you read your owners manual it tells you that the Evo should be run on 93 octane gas. But I guess you know better than those who made the damned car.
I know you do not like dynos. You made that clear on SoCal evo. Keep tuninng on the street and hopefully you will not get your car confiscated by the police like what happened to your pal Blaze
Yeah, the car posted better numbers over the IX turbo that he had, but that is nothing to brag about considering the the numbers with the 9 turbo were barely 300 hp. Something is wrong when a car with a 9 turbo, 272 cams, TBE and LICP, Works O2, and intake only puts down close to 300 hp. This is according to the 3rd gear pull he posted on the 9 turbo TUNED.
Do you honestly believe that these are healthy numbers?
getting your car confiscated has nothing to do with ACCURACY. are you a policitician? you argue like one... diverting and avoiding FACTS.
even if there is something wrong with the car... it's hte SAME **** THAT IS WRONG FROM RUN TO RUN.. i'll trust that over your OH LOOK I GOT NOTHING WRONG WITH MY CAR AND IT MAKES BETTER POWER SO IM GONNA MAKE A JUDEGEMENT ABOUT SOMETHING NOT ON MY MOTHER****ERING CAR
once again... i don't understand how people like you think...
I have logged two Evo 8s so far and in both cases there were spikes in the AFR indicating a misfire. The first sample came from my own car. It happened when the car was stock and it happened after the car was tuned. I posted about it here and on Socalevo. It drove me crazy. I tried changing plugs from stock to copper and from hot to one step cold. It did not work. Then I tried tightening the plug gap to 0.022. That did not work either. Then I tried an ignition booster and that failed to solve the problem.
Finally, I went out on a limb and started mixing gas to run 93-94 octane. One gas tank later and ALL the spikes in the AFR were gone.
The second sample belonged to a friend of mine. His was a stocak Evo with a TBE and intake and no tune running on 91 octane gas. I logged the SAME type of spikes in the AFR that I got on my car. I told him to start mixing gas if he wants to get rid of this misfire.
There is a thrid Evo 8 that I will log soon and if the same happens then that pretty much tells me that CA 91 pistane gas is a big problem for the EVO.
I really find it ironic that people buy a 32k car and they then skimp out on the gas to save a few bucks. If you wanted to use 87 octane, then you should have not bought an EVO.
seriously dude... scot tunes for 87 octane cuz he can. nuff said.
as for pd1's numbers... they're low cuz hey... he's boosting 23 psi. you ever think of that master tunerface?
#124
http://www.socalevo.net/forum/index.php?topic=21769.0
here's the great thread
so this guy starts mixing high octane fuel... and then starts touting that his 05 makes more power on higher octane fuel than pd1's car. credible? logical? comparable? OH HAIL YEAH... intranet me baby.
#125
some nuances in his setup like the cam timing etc contribute to slow boost up. some toher ones may contribute to his lack of timing.
#126
Did you bump timing right before spool up to help build cylinder pressure to lessen lag? I am thinking that there is alot left in the "lag" dept to be tried.
Why would advancing low rpm igntion timing improve turbo spoolup?
#127
Originally Posted by trinydex
still does not account for your false logic.... if you wanna follow the owners manaul... take that exhaust off and stop flashing hte ecu cuz the people that made the car know best.
#128
this is incorrect... pd1 has been chasing a bit of an octane related problem ever since he came to california... he doesn't like 91 octane gas and it doesn't like his tune... that's not to say that this turbo sucks it just means he moved to los angeles from pennsylvania.
Maybe pd1 should use mix 91 and 100 octane to get 93 octane to solve part of the car's problem
#129
#131
Originally Posted by evoNine
this setup is siiick!
#132
You are wrong. My car put down 295 whp on Tuning Tech's dyno on 91 octane gas, TBE, and filter. That is as good as pd1's car did with the 9 turbo and ALL his other mods. Here is the dyno plot.
#133
This is a personal account on ones turbo installation for general reading pleasure, thanks for the write up, not a study.
To be convincing with respect to turbos performance would require data logs and dyno pulls accomplished before (e.g. OEM turbo, 3071) and after (FPgreen) under no less than the following conditions:
1) Same car, tire pressure, fuel, dyno, degree and style of tune, MAF condition, and modifications.
Data logs in addition to boost pressure, assuming same ducting and crap are used, would compare the flow (hz vs psi) and efficiency for the particular setup.
We need an EvoM R/D department of people who perform performance part studies by a prescribed protocol. I'll donate $1
on what octane -just kidding
This is what the timing profile on my car usually looks like.
#134
WOW, talk about contradicting yourself I thought the Evo cna be tuned to run on 91 octane with no problems. It seems that at least pd1's car is having a problem with our 91 pistane gas.
you guys don't know him... he's been changing his setup constantly to try to find something he LIKES. i think he's found something now...
the fact is you haven't said a damn thing that makes any sense. if the car is underperforming hte results are inconclusive... but that's not your point was it...
i don't care if dynos are needed... it doesn't say anything about accuracy does it... that was MY point.
also i beg to differ about the 340hp arguement... on 91 octane gas running real 91 octane timing wihtout doping your fuel... it's DAMN HARD to surpass 350. i think you're on evom too much and you get duped by these "national" numbers.
show me a car that runs 23 psi on 91 octane... show me please. i'd love to see it. that's a car that's likely knocking. pd1 doesn't like having a single smidge of knock on his logs... i know i sat in the car with him while he tuned.
in the end... it doesn't matter... i'm sure people can see through your illogical posts and if they can't i can't care less if they join your bandwagon.
#135
What's best of all this **** is when you do question a vendor about how they dyno'd their product or how they tested it and disagree with their methods and/or the car they tested said product on, they say you don't know what you are talking about. Or that they aren't going to test it the way the majority of us want it tested because it is stupid to do it that way. Or even better they tell you to wait until someone else is stupid enough to buy said unproven product and test it on their car.<---- What the hell is that?
I have seen at least 2 major product releases in the past month turn out this way. It just goes to show me that these certain vendors aren't in touch with their customer base and have no desire to be. But their Fanboys are there to kiss their A$$es and praise them for absolutely nothing. End of Rant...Peace be with you.
