Oil drain plug crush washer.
Old Nov 19, 2006 | 07:15 PM
ak47po's Avatar
Besides the dealer does anyone know where to buy the oil drain plug crush washers.My MR has the oil temp sending wire right in the middle of the drain plug,so i can't change the drain plug every time i change the oil.I have only seen the washers sold together with the new drain plugs.
Old Nov 19, 2006 | 07:20 PM
LoCo4's Avatar
When you go get an oil filter from the dealer just ask for the crush washer for the drain plug. They SHOULD know what you are talking about.
You don't need to change the drain plug every oil change.....just the crush washer.
Old Nov 19, 2006 | 07:21 PM
Blue By You Evo's Avatar
the crush washers are M14 size from autozone or wherever, if your not using the oem filter and cant get one there.
Old Nov 19, 2006 | 07:22 PM
ak47po's Avatar
I know you dont have to change the plug every time,i have only seen plugs and washers sold together not seperatly.
tah78's Avatar
at the dealership, they have washer by itselft..normallly, they just throw one in the oil filter box
Old Nov 19, 2006 | 07:27 PM
They do come in packs of just washers. Just check at autozone or pepboys or somethin
Old Nov 19, 2006 | 08:39 PM
superscout03's Avatar
never had to change mine, no oil leak here.
Old Nov 19, 2006 | 08:40 PM
Ph3n1x's Avatar
Stopped using them since first oil change. No problems or leaks
Old Nov 19, 2006 | 08:48 PM
Reefer650's Avatar
Not to smart... #1 oem filters are ALWAYS BEST. Theres no reason why you need an autozone one they just elevate the amount of oil flow and I dont know about you but a mixture of grinding and oil should be well filtered not free flow.. #2 Just ask for a crush washer at any dealership most of the time its free but some guys will charge like 2 bucks (I know for fact my father owns a mitsu. dealership) better to be safe then sorry..
Old Nov 19, 2006 | 09:18 PM
manny85382's Avatar
Just go to the dealer ship they always include it with my filter.
Old Nov 19, 2006 | 09:25 PM
barneyb's Avatar
I sold my DSM with the crush washer it came with - no leaks. I plan to do the same with my Evo - 36k and no leaks.
Old Nov 19, 2006 | 10:22 PM
ntwaddel's Avatar
I usually order the filter & crush washer from works. they have the washer taped to the filter box
http://www.worksevo.com/store/produc...roducts_id=196
Old Nov 20, 2006 | 05:23 AM
aklucsarits's Avatar
My dealer charged me $1.99 each for the oil drain crush washer.
I'll get some at autozone for $0.05 next time.
Old Nov 20, 2006 | 05:38 AM
BADEVO's Avatar
The dealership here tapes one to the top of every filter box we buy.
Old Nov 20, 2006 | 07:32 AM
glgz's Avatar
I have never changed mine either and have no problems.
Quick Reply: Oil drain plug crush washer.
