Code PO230 Engine Overboost problem
Hey guys,
I got a problem with my 03 Evo. It kinda stals at 5000K-5500K RPM's. It keeps going until it reaches 5000K, stops - loud pop comes from exhaust and then keeps going. The car doesn't feel right. It does it sometimes, I'd say 2 out of 5 times when I push it that far. Last time I pushed it to 6000K rpm's it didn't pop, but check engine light came on. It gives me code 230 saying that Engine Has Overboost Condition. (I run 20 psi)
Any ideas why it might do that or what needs to be done to get it fixed?
Thanks
Thanks
Originally Posted by ixbreaker
are you sure your running 20 psi??? typically boost should taper when you reach high rpm...theoretically your running too lean at this rpm, which is why you hear the pop out of your exhuast. did you get a flash?
Originally Posted by Evolution[OH]
No flash, and it's 20 psi, but it goes up slightly at higher rpm's. I've got MBC
I'd think there's a lean or overboost issue with your MBC and Intake combo - being that you don't have a tune for either.
Either way, I'd back down the MBC. Did it recently get colder in your area, cause you'll boost higher in colder weather.
Originally Posted by boomn29
Goes up at higher rpm's.... that sounds backwards.
like everyone else is saying, get a tune asap.what gauge are you using? i would go over all of the boost guage connections to make sure it is reading correctly. when you set your mbc, you did set it for 20psi in 3rd gear right? hopefully you arent boosting 20psi in first or second
Originally Posted by IEXCELR8
So with the mods you have you have not had it tuned?
If this is the case get a flash asap...
I didn't cause I wanted to get cams and LICP and then get a custom tune from Al aty Buschur's. I live near and Al is out there evey month.
You used all new vacuum lines puting the boost controller in i hope....the pills in the stock one might make this happen.....just a thought
You might want to get a flash or get that thing tuned....get the Eflash cable for 89 bucks and buy a 50 dollar tune....honestly you cant go wrong
had one evo guy do it. I'm sure he did his best. I turned down boost to 17-18 psi, sicne it's winter anyways and the car will only be driven once in a while. So far the I had no problems, I erased the code and it did pop up anymore.
Thanks for your help though
twinspoolin94
Oct 15, 2015 05:28 AM
sphynx
Aug 9, 2011 05:29 PM
