Clutch Tranny Motor Mount or what
New car 1400 miles on it STOCK as a new born baby
I cant seem to shift smoothly, makes me feel like I cant drive stick PS BY FAR NOT MY FIRST MANUAL or first evo
Anyways as soon as I shift I feel (and hear) a slight clunk I mean slight. It doesnt happen all the time but actually seems to happen more as it warms up (most probs with others are the other way around).
The pedal engagement seems to be at the VERY end of release and to shift smooth I have to slip the clutch WHICH I HATE, or change gears very slowly holding the clutch in at the very end or I get chatter judder and slip. Especially happens when turning and engaging into 2nd I get a CLUNK then shift, release clutch, then there is a delay then the car goes
Ive narrowed it down to
clutch pedal adjustment
clutch gone (dont know how)
motor tranny mounts loose
air in clutch lines
cv joints
oh plus I get a loud whine in reverse
Any Info is appreciated!!!!!
air in clutch lines
cv joints
I do it sometimes myself. its normal if you are putting the car in gear withouth applying any gas when going into the low gears you can hear the clutch/drive axle engadge. its a pinging sound sometimes.. i could wrong though......
You need to adjust the clutch pedal. Theres write ups for it, just do a search. Im too lazy right now lol. Clutch should engage about halfway up or so, if your coming all the way out thats too far. Ive heard alot of new evo's need clutch adjusted.
here's how to adjust the pedal http://evomoto.com/tech_info.php?tec...54302afecef3f6
and here's how to remove the restrictor(this will add quite a bit of life to the stock clutch) http://evomoto.com/tech_info.php?tPa...54302afecef3f6
bbong
Jun 11, 2017 06:25 AM
Shastamiknasta
Dec 9, 2012 08:13 PM
undressesitself
Sep 9, 2012 09:48 PM
mojambo
26
Oct 18, 2005 09:49 PM
