cat delete=failed inspection
Old Dec 4, 2006, 08:18 AM
Nauticabri's Avatar
I'm sick of being given a hard time by my dealership and such saying they wont pass me on inspection because of my exhaust (no cat) here in NY state. I'm not willing to change my whole exhaust system or go back to stock just to pass inspection, anyone else run into this problem and what did you do, or what do you recommend? I'm not due for an inspection for a while (spring) but I'm just curious. Thanks in advance.
Old Dec 4, 2006, 08:26 AM
19psi's Avatar
just put a high flow cat and call it a day man.
The few extra hp with a testpipe is not even worth it IMO not to mention the penalty fee if you do get caught running a test pipe.
Old Dec 4, 2006, 08:27 AM
rice_rocket88's Avatar
Throw in a high flow cat.. or be sneaky and weld on the heat shields of a stock cat.
FYI if you grind the bolt holes you can put a stock cat inline with your system..
Old Dec 4, 2006, 08:32 AM
puff n pass's Avatar
is it the check engine light or the physical part that they are given you a hard time with?
Old Dec 4, 2006, 08:34 AM
talentsearch301's Avatar
+ 5000
Im running the WORKS hiflow cat and passed N.Y inspectionS
caswanso's Avatar
Do you not have a cell fix? I know in Texas they don't actually look under the car. They just plug it into the OBDII and as long as the check engine light isn't on and the O2 readings are within spec then they will pass it. Usually they don't look under the car unless they have a reason (i.e. Check Engine Light or O2 code)
Old Dec 4, 2006, 08:36 AM
caswanso's Avatar
I know that Texas is different then NY but maybe you can try a different shop...
Old Dec 4, 2006, 08:37 AM
cij911's Avatar
WTF ??? Are you seriously mad for an inspector to fail you because you have tampered with an emissions part (removed the catalytic converter)??? You are lucky they did not report you, fine you, impound your car, etc.
Per the other recommendations get a High Flow Cat....I have a true 3" Ultimate Racing Cat and it works great...
Old Dec 4, 2006, 08:51 AM
steveoevo8's Avatar
Where are you located?
Old Dec 4, 2006, 12:25 PM
2 fas 4 u's Avatar
why are u going to the dealer for an inspection if u have a check engine light when u need an inspection un plug battery so it can reset drive to get inspection that simple. if light comes on before u get there then reset it again thats it.
Old Dec 4, 2006, 12:34 PM
spdracerut's Avatar
Um, you're breaking the law. Why should they pass you?
rcheung's Avatar
kind of off topic here, but if i switch from a testpipe to a cat will a retune be needed?
Old Dec 4, 2006, 12:39 PM
Ultimate CC's Avatar
if you have a cel, get the spark plug fouler mod and go to a different shop...
Old Dec 4, 2006, 12:42 PM
mifesto's Avatar
cuz he's retarded... gut the emissions system and ***** cuz he failed the emissions test???? sigh!!!
Old Dec 4, 2006, 04:02 PM
cij911's Avatar
No....you should be fine if you are running a good, safe tune...
Quick Reply: cat delete=failed inspection
