View Poll Results: Should Mitsu recall the evo transfer case?
Yes
![](https://www.evolutionm.net/forums/images/polls/bar2-l.gif)
![](https://www.evolutionm.net/forums/images/polls/bar2.gif)
![](https://www.evolutionm.net/forums/images/polls/bar2-r.gif)
![](https://www.evolutionm.net/forums/clear.gif)
89
77.39%
No
![](https://www.evolutionm.net/forums/images/polls/bar3-l.gif)
![](https://www.evolutionm.net/forums/images/polls/bar3.gif)
![](https://www.evolutionm.net/forums/images/polls/bar3-r.gif)
26
22.61%
Voters: 115. You may not vote on this poll
Do you think Mitsubishi should place a recall on their transfer cases?
recalls are for safety issues- not gear whine or breakage from abuse. As said, when they start locking up and causing crashes then there will be grounds for a recall. That's what it took for the DSM recall and that's also what it will take here.
A "weak link" is not necessarily a flawed design. Every design has a weak link and often this is done on purpose. Something has to break, it's just a question of what. Would you like the TC, trans, and rear diff to all simultaneously explode when overpowered? Would this be a better design than one component, or link in the chain, failing first?
This is a safety issue hence my concern but not all recalls are for safety. If a part is faulty by design, the government can force a company to recall. And of course there is always a weak link, but the point here isn't to dispute that. Granted when something is abused, duh, it will fail but my point is that the failure of the tcase under normal conditions is a serious problem.
Im hoping to cause enough noise that mitsu will at least throw out a TSB. TSB's are actually a sneaky way for car companies to get out of full recalls. That way if you bring your car in for a clutch and they find the tcase is full of slack, they will replace it before there is a problem.
As far as replacing it with what, well, they could either redesign a tcase comparable to the JDM spec units, which are not prone to failure. The tcase in the USDM vehicles was a prototype and never used in any market so the fact that it is failing shows its inherant flaw. On another note, in speaking with people about this issue, it seems that it may even come down to something as simple as a quality control problem. Appearantly some of the tcases have a shimming issue leading to alot of slop in the gears. If it is something that simple, they could recall the shim itself and just replace them. IDK for sure what the problem is but I am hoping to pull apart my tcase and inspect the wear areas.
Also, Steve and value, realize that with Mitsubishi's past history with tcase recalls, that can be used to our advantage to help try and prevent people from dying instead of waiting for it to happen.
That's interesting... I have a new 06 MR with 800 miles on it, and I noticed even though it shifts like butter, there are certain points during shifting that are sticky like it won't go into gear just yet, I don't force it in, I sort of shimy it out and back in to prevent any misshift. I wondered if I needed new shifter bushings or something... I hope its not a gear shim issue ; ; ... what do you guys think? Help me out here!
-Concerned
-Concerned
-Concerned
-Concerned
Another possibility is the engine shifting, I found my situation improved alot when I installed an Engine damper (plus it eliminated the phantom knock I was getting when my downpipe would clunk)
i agree with you 110%. my friends 05 evo the transfer case went 3 times and mitsubishi said it was driver error. i think it is a bunch of bs..they def should be on recall cuz i have plenty of buddy's that there t-case went on them and they are driving like and average person with about 20k miles...it is such garbage how they can produce a well performing car with a piece a junk t-case...unbelieveable
Read up on Mitsubishi's truck lawsuit/recall in Japan. Their faulty truck hubs killed people before they finally recalled them after a long fought out battle.
![EEK!](https://www.evolutionm.net/forums/images/smilies/eek.gif)
I have always had that problem, the solution is having the gate alignment adjusted so they drop into gear properly. What is happening is the side movement and up down movement isn't quite lined up properly for the sliders to drop into gear easily.
Geeze... reading all the reasponses... I have so many questions more than I can post... such as:
Being that the MR is real smooth but concidering the guys original post was on a 5 speed... is the 6 speed in more risk than the 5 speed because you possibly might not be able to feel certain things to avoid damaging anything?
Also... (man this question is noobish please bear with me) but the thing I'm concerned with is why when doing quick 4k rev shifts does my car like make that "boom" sound(could it be from just the clutch it self)? is that the differentials's clutches? It sounds like if you've ever drivin in a car that doesn't have LSD, and the then the Differential sort of like locks up(not sure how to describe that) and the tranny is just pushing that power out but it doesn't go anywhere, so the differential just acts like a broke LSD and doesn't do anything but spin one tire while the rear end feels like its gonna pop off... it sounds just like that but it doesn't do that, you hear "boom" then after holding/pressing the gas it just goes... does it have to do with not having LSD in our cars or does our cars have LSD? Sounds noobish, sorry, but please enlighten me, I don't want to screw anything up.
Hmmm...
Driveshaft and bushings?... it sounds so clean though, its not rattling etc, as I said it really just sounds like the Clutch engaging real fast it is a noticible boom sound though. I just feel that if it was drive shaft and bushings it'd sound different but you could be right about that. I'm assuming what's happening is the whole drive train engagement just isn't ment for quick shifts? What could I do to improve, strengthen that aspect of the drivability?
Your friend has one of these problems problems
1. Needs a driving lesson
2. Whoever put his x-case together didn't do it correctly
it was said before recalls are for safety issues, and only if the potential insurance payouts are more expensive than the recall itself. So, dont expect Mitsu to do anything about it, hell you see stingy they are with warranties.
![Question](https://www.evolutionm.net/forums/images/icons/icon5.gif)
You know what I've been wondering... how exactly the ACD works... is it possible it could ever fail electronically and cause you to drive in undisired conditions, causing you to drive unintentionally abusive under certain types of acceleration? Maybe someone out there is using the incorrect ACD setting? Would that be a potential hazard? If the differentials lock up when they aren't supposed to such as too soon etc... in the end the stress goes to the tranny when the differentials fail... maybe I'm confused on how that works, but just an idea...
