GSC Releases our New S1 Cams for the Evo 9 Dyno inside!
Old Jan 3, 2007, 09:13 AM
  #106
Recks's Avatar
Do these cams make more power then the cosworth cuz I am still debating between the two cams specially now with the s1's... But I do plan to upgrade my turbo later on so maybe the s2's... And now hks has released there cam.. Just being tested... Ahhh! I want cams just don't wanna make a bad investment =P
Old Jan 3, 2007, 09:14 AM
  #107
Recks's Avatar
Are these numbers on pump gas? 91! 93?
Old Jan 3, 2007, 09:44 AM
  #108
GregGSC's Avatar
pump gas and how large of a turbo are you planning on running?
Old Jan 3, 2007, 10:57 AM
  #109
Recks's Avatar
30 or 35r
Old Jan 3, 2007, 11:13 AM
  #110
Recks's Avatar
But that won't be for a while lol 4-5k don't come around that easy for me
Old Jan 3, 2007, 11:22 AM
  #111
ROGERV's Avatar
do you have any #s on GSC S1 vs HKS 272 on Evo 8
Old Jan 3, 2007, 02:47 PM
  #112
Recks's Avatar
Man this is crazy! I want power! Lol what cams will help me get to 450 whp?
Old Jan 4, 2007, 01:17 PM
  #113
GokuSSj4's Avatar
i have a quick question
this are the specs on the new IX cams
The Evo 9 S1 cams are just awesome! The cams are suited to the stock turbo and valve train. We have made the gains and are super excited for these to be released next week.
Spec’s
Intake, 268 advertised duration 217 @ .040 with a peak lift of 10.8 lift
Exhaust, 260 Advertised duration 208 @ .040 with a peak lift of 10.3 Lift
my question is the following:
this set up will work best with stock turbo
how about if i decided to add headwork to the mix, shall i just purchase the new SC1 cams for the IX or would the SC2 work better if headwork and stock turbo is to be consider ?
Old Jan 6, 2007, 07:48 PM
  #114
SWOLN's Avatar
Greg can you tell me why the torque falls off so badly on this graph with the S1's? It seems the fall off is worse than the previous set-up.
Old Jan 6, 2007, 07:50 PM
  #115
Recks's Avatar
Cnt see the numbers what they say?
Old Jan 7, 2007, 09:09 AM
  #116
-=SPECTRE=-'s Avatar
Originally Posted by davidbuschur
Not thread crapping, asking a question. So these are new cams, not the ones sold 2-3 weeks ago?
David,
I think it's important for you to go back to your customer and confirm which of GSC's Evo 9 cam offerings he has. There are currently four:
280/280 (out for a couple of months now)
S1 (replaced the 280/280, were released a few weeks ago)
S2
S3
Old Jan 7, 2007, 09:57 AM
  #117
EVIL MR's Avatar
ok I keep my 272 ex cam in my 9 for now.
Old Jan 7, 2007, 10:06 AM
  #118
dubbleugly01's Avatar
Well I'm completely happy with my GSC's. These are the 280's (replaced by the upgraded S2's) on a 50 trim at 20#'s of boost on an Evo 8 w/93 octane pump gas. This is on a DD dyno mind you, which equates to roughly 400 whp on a dynojet. All this at 20#'s of boost. The GSC's are good cams. I can't see how they could lose 90 whp to some other cam. Yes, the 9's are different, but unless they somehow got the intake/exhaust swapped around backwards (can you physically do that with the cam sensor?), there's no way they're giving up 90 whp.
Old Jan 7, 2007, 10:23 AM
  #119
GregGSC's Avatar
thats the boost tapering off. we lost 3psi of boost from peak to redline.
as far as David’s questions.
These are a new lobe design so you have no experince with them. There are 1 set of S1 cams in a car and 1 other set in a customers hands in the US until tomorrow.. S1 is designed for the stock turbo. S2 is for a GT35-37 Turbo. And S3 is a custom cam that offers centerline movement to appropriately compensate for RPM range and turbo sizing. The Lift and Duration of the S3 is as far as a 4g cam should go with out putting undo stress on valve train.
This is in the thread many times. but i know how reading 10 pages of forums gets old. so there you go.
the old 280/280 mivec is a mild cam works on stock turbos and small upgrades. If you lost 90hp two things need to happen check the install and the tuner needs to adjust the mivec settings accordingly. also very likely the exhaust cam was installed off of the 112degree centerline or the intake was install incorrectly causing a serious loss in HP. If you have any questions on how to do either of these I will be more than happy to spend the time to walk you threw it.
Also just for everyone’s information I have not had one phone call from a customer claiming to lose 90hp. If I did have a phone call like that I WOULD WANT THAT SET BACK TO MESSURE. Hell if it is was one of my dealers doing the install I would more than likely pay them for there time to do it.
Greg
Old Jan 7, 2007, 10:54 AM
  #120
thector1's Avatar
When are these cams gonna hit the dealers?
Quick Reply: GSC Releases our New S1 Cams for the Evo 9 Dyno inside!
