Clutch Problem
Old Dec 15, 2006, 09:11 PM
dubbleugly01's Avatar
your throwout bearing separated from the pressure plate. It's not an easy fix. That's my guess.
Old Dec 15, 2006, 10:18 PM
C6C6CH3vo's Avatar
Attaching the TOB to the PP was even a PITA installing the clutch - I used about 4 different screwdrivers then suddenly got the hang of it.
If pushrod from cylinder isn't extended and pushing fork, then it's a leak
But if it's extended out it's separated. you might be able to snap it back in, adj pedal to the 30K wear, and it will hold for awhile but dont count on it. Expect new clutch.
Old Dec 15, 2006, 10:53 PM
speed-demon's Avatar
Originally Posted by STOCK_EVOLUTION
TELL ME ABOUT IT 16,000 MILES AND MY CLUTCH R.I.P!!!!!! GOT THE OLD PARTS BACK, FLY WHEEL AND PRESSURE PLATE WERE COOL BUT THE CLUTCH GARBAGE!!!! I DONT SEE WHY MITSUBISHI DOESNT FIX THIS ONGOING PROBLEM!!!!
mitsubishi doesn't want to fix it b/c they feel it is the best palce to make a weak link in the car to prevent some sort of catastrophic damage from occuring. instead, they decide to make the clutch go and thus have us forgo the repair costs rather than for them to put a good clutch in the car and fix whatever happens to break first.
Old Dec 16, 2006, 05:58 PM
Danny23's Avatar
That would be my guess also.
Old Dec 16, 2006, 10:52 PM
racer10's Avatar
i just had Buschur put a new clutch, pplate, line and shifter bushings in my 03' evo 1,500 miles ago. the other night on my way home from work, i go to down-shift into 4th so someone could pull into their driveway and the clutch went to the floor and stayed there. with the car running, it won't shift. turn the car off and you can shift it. i called buschur and they told me that it sounds like the retaining clip on the t.o.b. and that it will cost me $400 for them to fix it. does this sound right? or should they be a warranty thing?
Old Dec 16, 2006, 10:54 PM
TeamTurtle's Avatar
Evo's clutches are known to be awful. 30k miles on the stock clutch isn't bad.
Old Dec 16, 2006, 10:55 PM
34Turbo's Avatar
Thats pretty much how my clutch let me know that it was gone Time for a new clutch bud, good luck!
bbong
Jun 11, 2017 05:25 AM
evilution09
Sep 6, 2010 11:19 PM
TIGERJC
Apr 1, 2010 06:41 PM
bustin
12
Aug 8, 2009 10:22 PM
400AtTheWheelz
Jan 10, 2009 01:23 AM
Quick Reply: Clutch Problem
