FYI: front speaker sizing
I just removed the right front door panel to figure out exactly what size speaker will fit in the door. I measured mounting depth with the window down, and the depth is to the window itself, so obviously allowances will have to be made for clearance. I'm assuming the driver side is probably just a mirror image of the right, but I didn't actually measure it.
Here goes:
EVO 8 front speaker size
Hole diameter: 5 31/32" 150mm
Pre-drilled mounting holes: 6 7/8" 175mm
Mounting depth bottom: 2 3/8" 60mm
Mounting depth top: 2 3/4" 73-74mm
Mounting depth right: 2 1/2" 63mm
Mounting depth left: 3" 76mm
Mounting depth above surface of factory speaker: 3/4" solid, 1" including foam
Here goes:
great info!
were you able to fit 6.5" speakers in the door?
I would like to go with Boston Pros, but they are so damn deep that I might be forced to go with something shallower.
I didn't actually try to fit any speakers in the door. I was just measuring first to see what would fit. The hunt for speakers comes later. I would imagine 6.5" to 7" speakers would fit fine, although depth might be a problem and you might have to fit a spacer. The aftermarket speakers I've seen aren't as tall above the mounting surface as the factory units, so raising the height by 1/4"-1/2" should be well within factory speaker tolerances.
otter
90
Jul 11, 2016 09:23 PM
DuffmasterFresh
10
Mar 17, 2013 10:49 PM
bigd31388
33
Aug 20, 2012 07:59 AM
