Helix 3" Turboback Exhaust Review w/ pics
Helix 3" Turboback Exhaust Review w/ pics & sound clips
EDIT: Here's a video of the full turboback exhaust (w/ high flow cat): http://www.youtube.com/watch?v=xIfa9OBFIHo
I recently purchased a Helix 3" Turboback exhaust package from Gruppe-S at a very good price, and today, the installation began. Here's my story, please note, I've bolded the key points for those who hate reading long-winded posts.
The order consisted of:
Helix O2 Housing
3" Helix v2 Downpipe
3" Helix Cat-back Exhaust
I also purchased, from a fellow EvoM member, a used Helix 3" High Flow Cat to match the rest of the system. All in all, my total cost was $810 shipped. The installation was done by a friend of mine, as he owns a long-time custom exotic car shop, and has seen every performance part you can think of.
The order was placed & paid on 12/20/06 and the parts were received on 01/04/07 (with exception to the v2 Downpipe, which is backordered for another few weeks) that's an 11 business-day turnaround from Gruppe-S, which is great, considering it shipped for free, via UPS ground, from Cali to Boston.
The parts arrived in acceptable packaging, and the quality of the materials (as stated by my 30+ year experienced friend) was "absolutely exceptional. The welds, the material, the fitment... all some of the best work I've seen."
The installation was very straightforward, there were absolutely no fitment problems, HOWEVER, the bolts included with the product were very small (12mm, perhaps less). The job requires bigger, 14mm bolts, with lock washers to raise the head of the bolt away from the welds. This was disappointing, as I had to purchase approx $40 in hardware to install the exhaust properly. There was simply too much play in using the small bolts that came with the exhaust, and the larger 14mm bolts hold it extremely well.
The other point of note is that, the Cat-back section has a weld with a very tiny hole at the bottom. My tech said that it appears to be where the weld was started/stopped, and does not appear to be intentional, HOWEVER, he did say that often times, holes at the bottom of the exhaust near or at the muffler are intentional to drain condensation out of the system. I do not know whether or not this is intentional or just a small weld error, but either way, it does not "leak" exhaust or look bad whatsoever... there is simply small condensation drops (which is probably a good thing).
to be continued (O2 housing and downpipe yet to be installed)...
The sound of the system, as-is (with stock O2 housing and downpipe, but using Helix HFC and Helix Cat-back), is absolutely phenomenal. The low idle (900rpm) is virtually the same as stock. Low-to-mid revs are very deep and not even the tiniest bit raspy. The high rev is enough to make me smile every time I shift. It is fairly loud with just the HFC and CB, although I've heard louder (systems with downpipe & test pipe erupt a bit more than this does).
All-in-all, I'm extremely happy with my purchase. The hardware mistake is disappointing, and keeps me from saying this was a flawless experience, but at the end of the day, I know I've got a quality, great-sounding exhaust that fits like it should, looks like it should, and sounds like it should. Thank you to Gruppe-S and to Helix!
Here's some soundclips (these are from a digital camera so the quality sucks):
http://www.psysem.com/EvoIXStockExhaust.mp3
http://www.psysem.com/EvoIXHelixCatback.mp3
Helix O2 Housing
Well, I just received my Helix V2 downpipe from GruppeS. It looks flawless and definitely lighter than my earlier V1. But, you will be disappointed again because it did not include any hardware at all! No bolts and no gasket!
I have to say how impressed I am with this turbo-back system. I got the whole system shipped for about $850 with CA tax. I recieved the package 2 days after ordering. I got the catback, testpipe, and DP installed the day after, minus the o2 housing because the exhaust shop wanted me to bring the car in when they could let it cool for a few hours. They were scared to crack the turbo with it hot. Huge power difference with those 3 things. It sounds so mean at idle, and WOT it just houls like a beast. My car is in the shop as we speak getting the o2 housing installed. I will post some detailed pictures of the whole installed system later tonight.
yeah, you mean the CEL fix? Its got a hole in the catback to either plug in the o2 sensor if you have a testpipe, or plug it up if your still running a high flow cat.
