How much - Redline Water Wetter
Old Jan 6, 2007 | 07:39 PM
LoCo4's Avatar
Just need to know how much to put in to the system.
Old Jan 6, 2007 | 08:57 PM
hondafan's Avatar
whole bottle? not sure either, good ? what does the bottle say?
Old Jan 6, 2007 | 08:59 PM
BoostWhore's Avatar
I wouldnt use it.... A lot of people have had issues with it making their coolant turn brownish and look like theres oil in it.
Old Jan 6, 2007 | 09:02 PM
ak47po's Avatar
USE DIRECTIONS
One 12 ounce bottle treats 12-16 quarts of water or a
50% ethylene or propylene glycol solution. In smaller
cooling systems, use 4-5 caps per quart. Add directly
through the cooling system fill cap into the radiator or
into the overflow tank. Do not open a cooling system
while hot. For best protection for aluminum, replenish
or replace every 15,000 miles. The anti-scaling ingredients
in Red Line WaterWetter® allow its use with
ordinary tap water. However, using with distilled or
deionized water will accomplish some scale removal
in the cylinder head area. Plain water with or without
WaterWetter® should not be used in cooling systems
containing magnesium - antifreeze should be used -
with WaterWetter®. For maximum temperature
reductions use the most water and the least
antifreeze possible to prevent freezing in your climate.
Even in summertime the use of air-conditioning
can blow freezing air through the heater and cause
freezing of the heater core unless approximately 20%
antifreeze is used. Red Line WaterWetter® is available
in 12 ounce containers.
Old Jan 7, 2007 | 12:20 AM
LoCo4's Avatar
Alright the question is how many quarts is our system?
Old Jan 7, 2007 | 12:23 AM
LoCo4's Avatar
I read those threads and seen it isn't true.
Old Jan 7, 2007 | 09:28 AM
mrfred's Avatar
6.3 qts. You'll have to use a turkey baster to remove a bit of coolant to make room for the water wetter.
I've had it in my car for six months now. No problems.
Old Feb 6, 2007 | 09:29 PM
BoostWhore's Avatar
well mine did it.....
Old Feb 10, 2007 | 12:49 PM
dj_subculture's Avatar
I've used Watter Wetter in my SR20 in the past. And yes, it will turn change your coolant a diferent color. That's normal.
Old Feb 10, 2007 | 12:58 PM
talentsearch301's Avatar
I use it... no color changes for me
Old Feb 10, 2007 | 01:17 PM
Exciting News's Avatar
I think the oily goop formation is more likely if you add it to the overflow versus directly adding it to the radiator. That was my experience in my previous car.
turboked
Feb 12, 2008 03:02 PM
fletch
Jul 5, 2005 08:34 AM
jkisineffect
Feb 14, 2005 06:27 PM
pyrovice
Jan 21, 2005 07:33 AM
The Emperor
14
Jul 18, 2004 02:22 PM
