ATP Turbo Kit Intake Solutions
ATP includes everything in their turbo kit to supposedly make it "a direct bolt on replacement." As many of us know this isn't exactly the case; but regardless, the largest problem plaguing me at this point is an intake pipe/system that utilizes the stock MAS. ATP does not include any intake solution with their kit, and odviously the stock intake pipe isn't going to mate with the inches larger cold side of the GT series turbos. Another problem is making a pipe that fits the larger GT turbo but reduces enough to fit the much smaller MAS without creating a suction problem inside the intake tract (though this problem has already been solved by many vendors intake pipe offerings). Lastly, supposedly regular GT series intake solutions that are offered don't fit ATP kits right because of the different placement of the turbo caused by using the stock manifold.
SO i need help finding a solution. I have talked to a couple ATP kit owners that have already made intakes work that utilize the stock MAS, but i couldn't get many answers out of either of them.
One of which used the Injen intake w/ UICP for the stock turbo, but that is all the info i got from him, i have no idea how he made this work with the larger GT turbo. Though this does seem like the most logical option seeing as it is made for use with the stock MAS and also is made for the same turbo placement as is offered by the ATP kit/stock turbo. I'm sure it is as easy as just simply purchasing a reducing coupler that reduces from 4" to 3" where the intake pipe meets the turbo cold side. But i just really am not sure if this is truely how it was done, or if this will work without problem, or where to get such couplers.
Next another ATP owner stated that he used Shearers intake solution for their similar gt turbo kit. Though this user wouldn't provide me any fitment information or any photos. So i have no idea if he had to do any custom fabrication or not.
So i guess i am just looking for some help here. I know this seems simple for most of you; but i am the type of person that won't even be installing my turbo kit myself and i will not be able to custom fab something myself. I just need to know what to buy and from where, in order to make an intake pipe that uses the stock MAS and mates to a gt30r that is mounted in the same position as the stock turbo.
Any info helps, thanks.
Well i can't exactly just drive down there and have on fabbed up, i live accross the US from AMS; and this isn't any regular gt30r. Unless you are using an ATP kit that they already have a jig for... I'm also hoping for something a little cheaper and more generic then having something custom fabbed. Of course i could just have something custom fabbed by a shop, but i was just hoping there was an easier/cheaper solution out there that is proven to work and not create a vacuum.
You probably need a 3 inch to 3 inch coupler. That is what i needed for my injen intake with my rnr 50 trim kit. Just measure the diameter of your turbo inlet and see what size it is. My guess its going to be 3 inch. I bought mine from Horsepower freaks from eric and like i said it was 3inch all the way through.
If stock inlet is 3" and gt30r has 3" inlet, than just any stock turbo intake would work... I am pretty sure the gt30r has a 4" inlet. Do you guys think a 4" to 3" coupler is going to work fine, suction wise?
Are the couplers on this site 4 or 5 ply? Do you know anywhere else i can get them, the largest they go on this site is 3.625" ID, which i don't think will fit over a 4" inlet.
http://www.boostcontroller.com/index...3868d244f372d8
here you go....
#ASCR3-X. Silicone Reducer - 3 inch length
its 4 ply.. 3 colors
and they come in the size you need
cheers!
here you go....
cheers!
